1.9 wraith stock tire/wheel question Has anyone pulled the stock tires off of the wheels on the 1.9 wraith and found out if they are a normal bead or a glue on only? I'm looking at one my shop has in stock and I can't quite tell. Like the bomber stock tires are only glue on so if you want to put on a set of bead locks you had to buy a set of tires as well ($50+ extra cost) |
Re: 1.9 wraith stock tire/wheel question I have had the R35 compound Trail Grapplers mounted up on a couple different sets of beadlocks. |
Re: 1.9 wraith stock tire/wheel question The RTR comes with the S30 compound and there is no mention of the bead in the axial info. |
Re: 1.9 wraith stock tire/wheel question I used a heat gun to remove mine from the stock wheels and the bead looked good and they mounted up with out problems. https://uploads.tapatalk-cdn.com/201...05ab940309.jpg Sent from my LM-V405 using Tapatalk |
Re: 1.9 wraith stock tire/wheel question The tire on Axial's page looks to have a normal 1.9 bead http://www.axialracing.com/assets/pr...jpg?1512669727 |
