05-12-2019, 09:44 PM | #1 |
Quarry Creeper Join Date: Mar 2007 Location: Celina TN.
| Wraith drive shafts
Has anyone came across these and tried them. I know MIP is the best out there but I'm not going to be running more than 2S on a 35t motor and for $16 bucks i would almost be willing to try them. They remind me of the Junfac design with the half moon design. https://www.ebay.com/itm/2-Steel-Hea...um=40169724153 |
05-12-2019, 09:49 PM | #2 |
Quarry Creeper Join Date: Jun 2013 Location: Australia
| Re: Wraith drive shafts
Yep, I've tried them. They lasted for a little while. Half moon design like junfac lasted fine, but the ends were the weak point. Probably fine on 2S. I use 3S exclusively. Sent from my SM-G950F using Tapatalk |
05-12-2019, 10:30 PM | #3 |
ive had them on my e10 for years now stock motor on 2s on another rig i did snap one the rig is 20lb on 3s geared way down i screwed the other shaft by cuting it down i cut off the part that catches the d part of the shaft also ive seen them for as little as $8 so look around |
05-16-2019, 07:11 PM | #4 |
I ran Junfacs on my AX10 for a couple years. 3s with an HH 13T Crawlmaster. Rig was about 9 pounds. No issues.
05-16-2019, 07:19 PM | #5 |
To be clear though, these are NOT Junfacs. I run junfacs without issue on my wraith but these are a cheap asain copy. Sent from my SM-G950F using Tapatalk |
05-17-2019, 06:26 PM | #6 |
Newbie Join Date: Apr 2013 Location: Raleigh
Pretty sure that is the same set that I have on the Wraith I just purchased this week. They don't seem to like the Castle Brushless system in the truck even on 2s. It explodes the joint at the transmission on the rear shaft within a couple minutes. I'm currently trying to figure out which driveshafts to get... really don't wanna spend the $72 on MIP since I just got the truck.
Wraith drive shafts - Similar Threads | ||||
Wraith drive shafts | CHROMECRAWLER | Axial Wraith | 37 | 12-22-2019 06:54 AM |
Wraith drive shafts | Jessf | Axial Wraith | 2 | 12-10-2011 10:00 PM |
Wraith Drive Shafts | craddock35 | Axial Wraith | 17 | 10-20-2011 01:51 PM |
