09-08-2019, 02:23 PM | #1 |
Newbie Join Date: Feb 2016 Location: Henry Co. GA
| Wraith Servo mount
Just had the servo mount cap screw back out on the plate. nylon mount to aluminum plate. cant loctite it, any recommendations? I assume that a common thing? |
09-08-2019, 03:08 PM | #2 |
Pebble Pounder Join Date: Feb 2013 Location: Fountain Hills Arizona
| Re: Wraith Servo mount
I replaced mine with a metal servo mount I believe the part was from Axial too Then I used machined threaded screws to replace the coarse threaded screws that attach the mount to the axle this holds tighter Hope this helps |
09-08-2019, 04:41 PM | #3 | |
| Re: Wraith Servo mount Quote:
but will be looking for the metal mount to loctite it Thanks! | |
09-08-2019, 05:42 PM | #4 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
Try some plumbing thread tape while you're waiting. It's often used in place of Loctite. Sent from my LG-H870DS using Tapatalk |
09-08-2019, 08:39 PM | #5 |
You can buy the standoffs (plastic or aluminum) separately, but for just a couple bucks more, this might be do the job better for you: https://www.amainhobbies.com/vanquis...SABEgLEfPD_BwE |
09-09-2019, 11:58 PM | #6 | |
Quarry Creeper Join Date: May 2019 Location: North Highlands
Thanks! | |
09-13-2019, 11:59 PM | #7 |
RCC Addict Join Date: Mar 2019 Location: Hemet
I’ve been having the same problem, especially since adding a savox high torque servo. I ended up installing some longer fine thread machine screws to replace the stock ones and hoping that does the trick until I can pick up the vanquish one piece mount. My local ace hardware has all the machine screws I’ve ever needed for a reasonable price. Good luck! Even with the vanquish mount you’ll still be mounting it to the plastic link mount/truss so machine screws are a good idea there unless you go aluminum link mount also just fyi |
09-15-2019, 08:10 AM | #8 |
Thanks for all the advice, you all have been very helpful... I will be going with the Vanquish one piece mount as well. Seems this is a common problem with upgrading to a high torque servo. Thanks again! Happy Trails! Crash13 |
