Thread: 1.9 battery mounts in 2.2?
Old 09-20-2019, 03:08 AM   #1
Default 1.9 battery mounts in 2.2?
has anyone used the battery mounts from a 1.9 wraith in the 2.2? the side frames they mount to are the same parts numbers and it look like it would replace the cross brace on the 2.2. the only thing that is different is the bottom part of the frame from what I can see. I know there are plenty of other options to front mount the battery, but I like how clean the 1.9 battery holder is.
drinkbrew is offline   Reply With Quote
Old 09-20-2019, 06:39 AM   #2
Default Re: 1.9 battery mounts in 2.2?
The battery holder from the 1.9 Wraith most likely won't bolt up to the 2.2 wraith frame as the 1.9 version has completely different lower rails with mounting holes the 2.2 version doesn't have. Also you have to buy the whole lower rail/skidplate/radio box assembly to get the 1.9 battery tray.
svt923 is offline   Reply With Quote
Old 09-20-2019, 10:43 PM   #3
2 of the 3 holes on each of the mounts go to the side rails which are the same part # for both. /So it would only be the bottom hole that could be different.
It's only $30, not a big deal. I wouldn't mind having the bottom frame anyways in case I ever wanted to convert to 1.9.
1.9 battery mounts in 2.2? - Similar Threads
battery mounts crawler nub Axial SCX-10 1 01-02-2011 01:03 PM
Battery Mounts... msd44 RC4WD Bully 2 07-03-2010 05:36 PM
Over the Axle battery mounts? Grumpster1980 Venom Creeper 6 01-26-2010 10:51 AM
Battery mounts... Deezul Axial AX-10 Scorpion 9 11-23-2008 11:04 AM
battery mounts demonoid369 HPI Wheely King 10 06-04-2008 05:34 AM
