01-11-2020, 08:13 AM | #1 |
I joined the Band! Join Date: Jan 2020 Location: https://t.me/pump_upp
| New Wraith owner
So I picked up this wraith for a project to build, I know it's got some mods done Brushless motor with a 24t pinion, spur is unknown but is metal Metal driveshafts Traxxas wheels and tires Here's a couple pics: https://imgur.com/a/kP2Mmie My question is aside from what I listed what's stock On this thing? Also does anyone make a front electronics tray? I plan on removing the brushless system and running a brushed Traxxas ESC/motor combo. Specifically the Titan 12T 550 would that be alright for crawling and trails with the 24t pinion? |
01-11-2020, 08:24 AM | #2 |
RCC Addict Join Date: Sep 2014 Location: Ft. Lauderdale, Florida
| Re: New Wraith owner
Why do you want to remove the brushless system? You'll burn out that Titan 12T motor. If you want to go brushed, go with a 21t motor on 3s lipo. Honestly, the brushless system is much better than the Titan brushed Sent from my LM-G710VM using Tapatalk |
01-11-2020, 08:39 AM | #3 |
| Re: New Wraith owner The motor in it is better suited for a touring car, on 2s it will do wheelies. I do have a 13t pinion laying around that I could use instead
01-11-2020, 09:22 AM | #4 |
The 550 won’t fit without trimming the link mount or spacing the tranny up a little bit. That said, I do have a Wraith running a 21t 550. Lol.
01-11-2020, 10:26 AM | #5 | |
| Re: New Wraith owner Quote:
I swore it was a 21t the motor/ESC combo was pulled from my old Traxxas GT when I went with a brushless castle setup. my smallest pinion that i got is a 21t pinion. I feel the speed might be overkill on the wraith with that setup. I suppose though it'll be better then the 4600kv brushless setup in it now. | |
01-11-2020, 11:15 AM | #6 |
There is a thread in this section relating to motor/gearing combos. Have a look through it and see what’s worked for others. If you go brushed get a HobbyWing 1080 ESC. Best bang for your buck available. |
New Wraith owner - Similar Threads | ||||
New Wraith owner | Nails | Axial Wraith | 0 | 08-31-2016 05:21 PM |
new wraith owner!! | Wilt | Axial Wraith | 4 | 06-10-2015 04:35 PM |
new wraith owner here | yellow1000 | Axial Wraith | 10 | 08-10-2014 03:47 PM |
New wraith owner. | puddin | Axial Wraith | 48 | 03-23-2013 06:06 PM |
new wraith owner | ld markey | Michigan | 12 | 10-31-2011 06:04 PM |
