03-20-2020, 02:53 PM | #1 |
Newbie Join Date: Mar 2020 Location: Boise
| Wraith tire and wheel upgrade
So I bought a set of Pro-Line Wheels to replace the stock. They say they fit on any 12mm hex hub. Last night I could not get them on my wraith. The internet says that the Wraith has 12mm hubs and that the Pro Line wheels fit 12 hubs. Anything that I'm missing. I wiggled and pushed pretty hard.
03-20-2020, 03:53 PM | #2 |
| Re: Wraith tire and wheel upgrade
Welcome to the site! The Wraith typically has a "step" or shoulder on the 12mm hex. Change your hex to a normal, flat hex. It's stupid the Wraith ever got those odd hubs. |
03-20-2020, 04:03 PM | #3 |
Newbie Join Date: Nov 2019 Location: US
You can try buying new 12mm hub adapters for the wraith, just make sure the inner diameter is the same. Most 12mm hexes designed for metric sized axels are the same. I used to run some boom racing hubs on my Wraith before I sold it. Sent from my iPhone using Tapatalk |
03-20-2020, 04:35 PM | #4 |
...or, you can just drill out the hole in the center of the wheel to accomodate the shoulder of the Wraith's hex.
03-20-2020, 11:37 PM | #5 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
^ ^ What Jato said. Personally, I wouldn't drill out a brand new set of wheels. In the short term, it might be possible to get rid of the "step" on the Wraith hexes by putting them in a vise and taking a drill bit larger than the OD of the step and carefully drilling it down until the hex surface the wheel sits against is flat. Easier if you have a drill press and even easier if you have a lathe. Hexes come in different thicknesses so check whether the thickness of the stock Wraith hex will work with your new wheels. Sometimes, depending on the wheel offset, you might need a thicker hex. 12mm hexes also come with different bores, the most common being 5mm diameter. IIRC, the Wraith axle is 5mm where the hex fits on. |
Wraith tire and wheel upgrade - Similar Threads | ||||
Wheel and tire upgrade | nickel417 | Axial AX10 2nd-gen | 1 | 06-21-2012 06:48 AM |
My Slash wheel/tire upgrade | OlYelr | Non Crawler RC's | 9 | 11-20-2008 03:21 PM |
Free Nylint Wheel/Tire Upgrade | rockrunner | General Crawlers | 3 | 07-14-2006 09:06 PM |
