03-30-2020, 04:22 PM | #1 |
Rock Stacker Join Date: Mar 2020 Location: Grass valley
| New steering servo do I need a BEC
I purchased a savox sw1210sg steering servo and all I did was install it on a stock wraith rtr. The truck will run until load then beeps and shuts power off
03-30-2020, 04:23 PM | #2 |
Rock Stacker Join Date: Dec 2013 Location: Texas
| Re: New steering servo do I need a BEC
What esc do you have? Sent from my SM-N960U1 using Tapatalk |
03-30-2020, 04:24 PM | #3 |
This is the servo
03-30-2020, 04:25 PM | #4 |
| Re: New steering servo do I need a BEC |
03-30-2020, 04:28 PM | #5 |
I would say yeah, you need a BEC. That stock esc in the wraith doesn't have a great BEC. What kind of load are you putting on your wraith? Sent from my SM-N960U1 using Tapatalk |
03-30-2020, 04:31 PM | #6 | |
| Re: New steering servo do I need a BEC Quote:
Like when I’m turning hard and using throttle same time Last edited by 530crawlers; 03-30-2020 at 04:34 PM. | |
03-30-2020, 08:08 PM | #7 |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
Yup, BEC in order. An alternative, and not a popular alternative by members of this forum, is a glitch buster. Glitch buster I tried one years ago because I was a noob and had no idea what a BEC was and how to add one to an RC. Didn't work out that well for me. Finally had to figure it out and add a BEC. Been a convert ever since. |
03-31-2020, 11:02 AM | #8 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
Yes, you need a BEC. High powered servos pretty much always need more amps than what an ESC can supply and Savox are notoriously worse than most other brands. Just to throw some numbers at you to increase understanding: Most high torque servos pull around 3Amps or more Savox servos are typically more like 5Amps Onboard BEC in almost every ESC is 1Amp, sometimes 3 at peak Castle BEC does 10Amps Mamba X has 8Amp BEC built in A glitch buster might help a little but they can't usually sustain output for long enough to help enough to power a servo. If you've got some capacitors around (and know how to use them without causing an explosion) than it might not be a bad idea to try it out and see if it helps. But really, a Castle BEC for $25-$30 is what you need. |
New steering servo do I need a BEC - Similar Threads | ||||
Bec hook up to run a steering servo | Gmader1 | Electronics | 1 | 10-09-2012 11:17 PM |
BEC and High Output Steering servo??? | AsILayDying | Newbie General | 17 | 08-24-2011 07:07 AM |
BEC and Steering Mystery | Harvo | Electronics | 3 | 08-01-2009 10:51 AM |
Mamba max, 11.1 1350 mil 25c, 5955tg steering servo, 5645mg dig servo | BEAU | Electronics | 5 | 01-21-2009 02:36 PM |
