Thread: Rock Bouncer wraith base
Old 08-14-2020, 09:56 PM   #1
Default Rock Bouncer wraith base
I have started rock bouncer project.
Now 90% has
completed.
Axle: KYK Diamond Axle
Transmission: AX 2 speed
ESC: Mamba X
Motor: Castle 2400KV 1415 550 type
Battery: Lipo 4s 3300mah
Final gear ratio
1st gear 68
2nd gear 24
(Using 15T pinion and 54T spur gear)
Naoki is offline   Reply With Quote
Old 08-15-2020, 12:20 AM   #2
sketchiness abounds...
durok's Avatar
Default Re: Rock Bouncer wraith base
Looks like a fun build!
You've got a great imagination - your Gmade R1/Capra and this both are very interesting...
durok is offline   Reply With Quote
Old 08-15-2020, 01:27 AM   #3
Thanks! Wraith RB project was very quick work because there is almost no material work for cutting or bending. Only body panel work and battery tray working is remaining!
Old 08-15-2020, 04:02 PM   #4
That's a really sweet rig.
Seems very well thought out.
I love the battery location.
Just curious, how does the battery come out? Through the front?
MRCrackhead is offline   Reply With Quote
Old 08-19-2020, 09:34 AM   #5
For high speed drive stability, I installed sway bar and also purchased Vanquish AR60 axle to make open differential. All for speed driving
Old 08-19-2020, 09:49 AM   #6
Yes. Like this.
But I will make battery box lower section by cutting the current batt plate to realize low center of gravity as much as possible.
Lipo 4s power is crazy therefore set up is quite severe.
Old 08-21-2020, 09:46 AM   #7
My kind of rig dude....
Very well done and thought out.
Postclanker is offline   Reply With Quote
Old 08-21-2020, 02:12 PM   #8
I have cut off original battery plate and made a new plate for relocation. It was a little bit tough work. I can put 1500mah 4s x 2 on this tray.
Old 08-23-2020, 12:54 AM   #9
I cut body panel and installed Led light for night run
Old 08-27-2020, 05:53 AM   #10
Done Interior work
Old 09-04-2020, 07:59 PM   #11
I made some modification because stability over 25mph was not good and handling under high speed range was difficult.
1. Add front sway bar
2. Front open differential/Rear spool diff
VP axle is temporary use. I’m ordering SSD diamond axle. VP axle to be used for another project
3. Longer wheel spacer (16mm) for stability at high speed range.
Old 09-04-2020, 08:03 PM   #12
I also changed the skid plate and link arm to HR because previous one was like junk product (threw away!)
Old 09-06-2020, 05:55 AM   #13
Test drive today.
Good traction and stability.
Handling getting much better.
Max speed was 54.8km/h
Old 09-11-2020, 12:14 PM   #14
I have modified Front wraith / rear RR10 link.
Long wheel base for hill climb.
Old 10-05-2020, 08:55 AM   #15
That looks like quite the beast! When do we get video of 4s sand spray action? Keep up the good work.
meatmonkey is offline   Reply With Quote
Rock Bouncer wraith base - Similar Threads
Wraith based Rock Bouncer mewalsh100 Axial Wraith 161 03-16-2019 12:12 PM
Want to build a wraith rock bouncer skift Axial Wraith 21 02-04-2014 11:38 PM
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
