02-14-2021, 03:32 PM | #1 |
Rock Stacker Join Date: Jul 2020 Location: USA
| Gear and pinion mesh problems
Has anyone else had problems with the axial hd underdrive gears meshing up? I put the stock hd gears in the front and they were fine but the rear seems to have a “sticky” spot when rotating. Seems like it may be ok once they get run for a while. Used new diff cups to and took the axle apart and reset twice to try and remedy.
02-14-2021, 04:38 PM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: Toxaway
| Re: Gear and pinion mesh problems
Probably just need to shim the pinion. I had this problem on my scx10iii. Added one small shim and smooth as butter after that. Sent from my SM-G975U using Tapatalk |
Gear and pinion mesh problems - Similar Threads | ||||
YXL Differential Bevel/Pinion gear mesh/gap | tonyfalkon | Axial Yeti XL | 82 | 07-26-2016 05:31 PM |
Pinion gear and ring gear mesh question | flyboy320 | Axial Wraith | 18 | 01-09-2016 02:41 PM |
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
Pinion Gear/Mesh? | 28offroader | Venom Creeper | 9 | 01-26-2011 01:21 AM |
Spur and pinion gear mesh | desertfox62 | Axial AX-10 Scorpion | 15 | 01-17-2009 04:35 PM |
