08-21-2021, 07:51 PM | #1 |
RCC Addict Join Date: May 2009 Location: In the warmth!
| Robotboy's Wraith Rock Racer (A transformed 1.9 RTR)
I wanted to build something "new to me" and missing a Wraith in the stable I figured I'd give this a shot. Going for an all around fun rig, some speed and some crawl-ability. Going to be a work in progress. Seeing what works and what needs to be changed. I picked up the 1.9 RTR, took a pic and did a total disassemble on it. Outta the box... Picked up an Element IFS kit and through it underneath. I did some research and from what I could gather I thought it would fit. So happy when it did. Next up I wanted trailing arms in the rear. Went with the SSD Bomber ones and used shorter rod ends. They're still a bit longer than I wanted but they'll do for now. Right now the wheelbase is sitting at 12.75". Eventually I'd like to get it to at least 12.5. Dropped in some MIP driveshafts and installed the IFS skidplate. Electronics installed. CC 2850/Mamba Micro X ESC, SPT 25kg servo, RX bypass and Hobbystar 6A BEC. Going with RC4WD 1.9 MT Baja Pro X tires stretched on some Chanquish 2.2 beadlocks. Mixed and matched some parts to come up with a rear sway bar. On the fence about having one at all but thought I'd try it. After a small test run the Wraith is better in higher speed turns but I think it's too stiff for anything else. I'll have to come up with something with a little give. This one has none. More to come.... |
08-24-2021, 09:06 PM | #2 |
| Re: Robotboy's Wraith Rock Racer (A transformed 1.9 RTR)
Very creative build, side profile looks great! Interested in seeing the rig all buttoned up with the panels installed... (btw - seeing those tires installed with some dirt on 'em makes me all the more embarrassed that mine are still unmounted!) |
08-25-2021, 05:47 AM | #3 |
Nice work adapting the IFS!!
08-25-2021, 02:51 PM | #4 | |
| Re: Robotboy's Wraith Rock Racer (A transformed 1.9 RTR) Quote:
great on this type of rig. Thanks! I've only run it for a few minutes so far but it's gonna be fun Last edited by Robotboy; 08-25-2021 at 02:53 PM. | |
08-25-2021, 05:36 PM | #5 |
She's a runner I'm still gonna try some things and upgrade when I can. I put in an order for some shorter trailing arms. That was a pain, seems no one makes them anymore. Only ones available are for Ryft, Yeti or Bomber. I want to cut down the wheelbase .25-.5", for aesthetic purposes, functionality wise it works great. Anywho... As for the cage I did the fastback mod and slightly bob-tailed the rear. I also bob-tailed the body so it fit snug on the cage. Added the SSD chassis stiffeners to the front. Figured they would help cause of my terrible driving The body I peeled the decals, lightly sanded, rust colored primer, thin coat of white, hit it with the bright yellow and then put a couple coats of clear matte. Came out fairly good considering my lack of talent. I found an old sticker sheet from my first Wraith, way back when, and put a couple on for good measure. Found some door handles and put them on as well. I bent the roof panel and cut it to make a bikini top. Still lots of little things to do but here she be... for now. Specs: Axial RTR 1.9 Wraith. SSD front chassis braces. Element IFS Kit. Axial Ar44 rear axle w/BR UD 33T/8T. VP 3 Gear Trans. MIP driveshafts. SSD Bomber trailing arms. Castle Slate 2850kv BL motor. Castle Mamba Micro X ESC. SPT 25kg servo. Hobbystar 6A BEC. Axial SCX10.3 shocks. RC4WD 1.9 MT Baja Pro X tires. Chanquish 2.2 aluminum beadlocks. Last edited by Robotboy; 02-01-2022 at 12:43 PM. |
08-25-2021, 09:23 PM | #6 |
The mods to the body look fantastic! Yeah, Twin Hammer trailing arms are VERY hard to find - JEC Racing might have been the last place to get them... Maybe the Element Gatekeeper ones would work? You could always pick up a set in plastic to test for cheap, then get the aftermarket aluminum ones that are starting to show up. Last edited by durok; 08-25-2021 at 09:25 PM. |
08-26-2021, 01:32 PM | #7 | |
out. SuperShafty stop making them, it looks like Blue Monkey RC is gone and the JEC are a no go. No plastic ones anywhere either. I think the gatekeepers will be too short. Fingers crossed on the integys, one of my least favorite brands. I've run it a couple times and it's a blast. I smell upgrades a comin' | |
08-28-2021, 12:09 AM | #8 |
Newbie Join Date: Aug 2021 Location: Nicosia
Nice build! Is the body the same as a 2.2 Wraith? |
08-28-2021, 07:08 AM | #9 |
| Re: Robotboy's Wraith Rock Racer (A transformed 1.9 RTR) |
09-03-2021, 02:38 PM | #10 |
Rock Stacker Join Date: Mar 2020 Location: Bay area
what length shocks are you running? I have mine tore down right now, new bearings and stainless screws.
09-03-2021, 02:42 PM | #11 |
post up and see if anyone has some of the VP trailing arms. When I had my TH I did all the available VP upgrades.
09-04-2021, 07:39 AM | #12 |
I've got a set of the plastic Vaterra ones. PM if interested.
09-04-2021, 12:29 PM | #13 |
| Re: Robotboy's Wraith Rock Racer (A transformed 1.9 RTR) They're the 90mm SCX10.3 shocks. Appreciate it but I don't think they will work. I picked up a set of Integys but the shock mounts on them are too far forward for my needs. The stocks are fixed length so I can't fiddle with rod ends to make em work. Thanks though. |
10-04-2021, 05:43 PM | #14 |
Still messing with the Wraith. A few upgrades. And some necessary fixes were needed. Picked up a SSD High Ratio Wraith trans and added a VP slipper eliminator. Running 54T spur & 13T pinion. The speed is great...for my needs Also added a set of Eyeball Engineering Link Tweakers for the rear. Perfect fitment and put my rear uppers where I wanted them. Finding that the Element IFS unit has it's problems. After 6 ten minute test runs I've blown out 2 sets of the 5x10 bearings, 1 set of 5x10 bushings and, of course, the diff gears when the bearings failed. Replaced the ring gear with the machined version and grabbed another pinion. For the gearbox I drilled out the front bearing pocket to use a 5x11mm bearing. Closest bit I had was about 10.5mm. A little small but it's clamped in there. I have about 20 minutes on it now, running hard, and no problems yet. Fingers crossed. I really like the way it drives with the IFS so I'm hoping it holds up. If not it's back to an AR44. |
10-04-2021, 06:22 PM | #15 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
It definitely looks like a fun rig to bomb around, nicely done. The thread is enjoyable, all meat and potatoes. ; Killer, no filler Sorry to hear the IFS wasn’t up to the task. Hope the upgrades hold together for you. Will indeed stay tuned. The 1.9 Wraith has been calling name for awhile |
10-04-2021, 07:14 PM | #16 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
Looks like enough material there to dremel it out for a larger one once that one fails at least. Sent from my SM-G970U using Tapatalk |
10-05-2021, 09:06 AM | #17 |
Quarry Creeper Join Date: Mar 2020 Location: Las Vegas
I like that quite a bit. Well done! s |
10-05-2021, 06:08 PM | #18 | ||
Gonna do a little beating on it and see what happens. Fingers crossed Thank you sir! Quote:
I was just thinking if I drilled straight through the housing, 11mm, I could maybe use a flanged 5x11 inside and out. That may be a usable fix. Hum... | ||
10-05-2021, 10:36 PM | #19 | |
RCC Addict Join Date: Jan 2009 Location: Bend
If you have a spare IFS bulkhead laying around send it to me and I'll whip up a problem solver for ya real quick like. You want a 5x13 inner and an outer 5x11? Or you wanna go bigger? 5x14x5 inner, 5x13x4 outer? You'll be chipping gear teeth before you hurt the bearings either way. Sent from my SM-S111DL using Tapatalk | |
10-06-2021, 06:37 PM | #20 | |
one cause I had to open it up so much to fix stuff. But it's still good if you'd like to try that one. I was just looking at it and I think the biggest we can go is a 5x12mm. Any bigger there won't be much meat. | |
Robotboy's Wraith Rock Racer (A transformed 1.9 RTR) - Similar Threads | ||||
💥 Axial Racing Weekly Sale ~ Wraith Rock Racer Buggy RTR!💥 | RPP Hobby | RPP Hobby | 0 | 05-21-2018 11:43 AM |
Sale - Axial Racing Jeep Wrangler Wraith-Poison Spyder Rock Racer RTR! | RPP Hobby | RPP Hobby | 0 | 02-23-2018 04:10 PM |
RTR AX10 Gone Rock Racer........ | BENDER | Axial AX-10 Scorpion | 92 | 02-29-2012 10:07 AM |
