![]() | #141 |
Pebble Pounder Join Date: Sep 2008 Location: Scotland Neck
| ![]() If you guys want shocks that don't leak. Try Jato shocks. I have been racing Jato's for eight years and I have not had a single leak. Never had to replace or top off. I probably changed the oil four or five times but I never had to replace a seal. Damn, I think I talked myself into putting them on my XR10.
![]() | #142 |
RCC Addict Join Date: Jul 2008 Location: San Diego
![]() | #143 |
Newbie Join Date: Dec 2011 Location: Erda, UT
What replacement gear sets are you guys running ? I blew my set up !! Just trying to tune my fx-r...
![]() | #144 |
![]() | #145 |
Rock Stacker ![]() Join Date: Jan 2012 Location: On the ledge. Look up.
Nothing flashy, but I always appreciate people mentioning simple and practical ideas for stuff. Figured I'd pass this on. I still like to experiment with different lengths of external shock limiters, but get tired of removing the rod end to do it. 5/32" ID vacuum line costs about 70-cents a foot at an auto parts house. It's thick-walled so you can cut whatever lengths you want, then slit the hose vertically. You can pop it off and on without doing anything more than lifting the shock spring. And the thick wall keeps it from popping off the shock shaft. For what it's worth. |
![]() | #146 |
| ![]() I just picked up a brand new kit and the instructions are a bit different for the screws for the axle brace. Left most screw that is listed above as an AXA466 (12mm long) is now an AXA467 (15mm long) LONGER Center screw listed above as an AXA466 (12mm long) is now an AXA465 (10mm long). SHORTER Right most screw (THE ONE THAT WILL INTERFERE WITH BEARING AND ALIGNMENT IF TOO LONG) is listed above as an AXA465 and is still listed as an AXA465. SAME So, looks like they shortened up the middle screw and lengthened the left screw. Last edited by ik632; 01-22-2012 at 12:39 PM. |
![]() | #147 |
Pebble Pounder Join Date: Nov 2011 Location: Yucca Valley
Nice write up Bender!!! awseome stuff from everyone. Quick question, is your chassis intentionaly backwards in the first set of pics? When I look at your setup sheet the schematic insinuates that the longer skinnier horn is indeed the front where as the stock chassis is exactly the opposite. I almost followed suit with your pic but realized its intended direction after assebly!!!! DOPE homer would say!
![]() | #148 |
Rock Crawler Join Date: Oct 2011 Location: smithville
Do you mean D'oh?
![]() | #149 |
Stock Shock lower seal: If you lose or ruin the stock o-rings, #6 o-rings from the plumbing section in the hardware store work as a suitable replacement. They are a little thicker so you won't get the bottom screwed on and will see the o-ring just a little. So far no leaks. |
![]() | #150 | |
Pebble Pounder ![]() Join Date: Feb 2012 Location: wooster
Either im confused or disoriented but my lower links mount horizontally under the lower shock mount. Yours seem to mount/bolt up vertically. Am I missing something? Quote:
![]() | #151 |
Shelf queen ![]() Join Date: Aug 2008 Location: Internet
![]() | #152 |
![]() | #153 |
Newbie Join Date: Jan 2010 Location: Las Vegas
Hey guys, I am running all stock but the stage three high clearance links and proline chisels and the tires rub the front springs and cups at full steering. Is there a mod for this or should I limit the epa or just let it rub? Thanks for any help.
![]() | #154 |
Rock Stacker ![]() Join Date: Dec 2011 Location: Riverside
Having some weird noise in my airtronics digital 94851 steering servo. my tires turn fine both directions but when I turn twoards the left the servo keeps making a sound like its still trying to turn. And for a little while this morning it didnt want to turn one way but then went a way. Any ideas?. And do I have a pretty good steeri g servo?. My email is waitin4dv@yahoo.com im still trying to get set up on thos site with some pics. what should I do new gears or new servo. And where can I het nee gears from. Its a airtronics digital 94851. Last edited by Waitin4Dv@Yahoo.com; 03-04-2012 at 03:19 PM. |
![]() | #155 | |
Pebble Pounder ![]() Join Date: Mar 2012 Location: Visalia
| ![]() Quote:
![]() Since you could potentially have other damaged parts within the servo besides gears, I'd invest in a Hitech servo (if it were me). I've been running an HS-7954SH with no mercy and with no issues. It's affordable and super tough. It has about twice the torque of your 94851 and would be a good investment. Just my 2 cents... | |
![]() | #156 | |
| ![]() Quote:
![]() | #157 | |
| ![]() Quote:
![]() | #158 |
RCC Addict ![]() Join Date: Dec 2006 Location: Oak Ridge, TN
The 7950 has more torque and Ti gears.
![]() | #159 |
![]() | #160 | |
| ![]() Quote:
Adding caster also helps. | |
