08-20-2010, 12:34 PM | #1 |
Quarry Creeper Join Date: May 2008 Location: Clarkston
| I´m having serious GAS
Gear Aquisition Syndrome It´s pretty much stock... The paintjob is "Cornholio on fire" Uli Last edited by Uli; 08-20-2010 at 01:14 PM. |
08-20-2010, 12:36 PM | #2 |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
"Cornholio on fire"....do you need TP for your bung hole Nice looking rig. I like the black paint. Lets see some body off shots. Last edited by Pdog7; 08-20-2010 at 12:39 PM. |
08-20-2010, 12:50 PM | #3 |
Haha....is that on your roof?!?! "Stock"....ha! Is that dual brushless? |
08-20-2010, 01:05 PM | #4 | |
the roof is right next to the balcony, though. I´m talking about the rig itself being rather stock, not the motors. Two lLRP 17.5T x11 cans powered by the matching escs on 2S lipos does a good job. Very silent, smooth and throttle-responsive, especially since the xr10´s trannys are so quiet to start out with. Uli | |
08-20-2010, 01:16 PM | #5 |
08-23-2010, 07:10 AM | #6 |
Now having run a couple of packs with the original lid on it I must say it(before i painted it and posted pictures I had the old crowd-pleaser on it) works quite well. At first i was concerned that recoverys with a flipped over rig would probably be a hassle due to the large scoop on the roof, but no problem! The only thing i haven´t figured out yet is how to deal with the bodymounts, because this thing really eats up the bodyclips. I lost a bunch of them already... Uli |
08-23-2010, 07:57 AM | #7 |
Pebble Pounder Join Date: Aug 2008 Location: Cary, NC
| Body Mounts
Try this body mount. It's the best thing going since sliced bread. There are a couple types to choose from. Gunnar's Body Mounts: Gunnar's Body Mounts |
08-25-2010, 04:32 PM | #8 |
09-14-2010, 09:44 AM | #9 |
Some machining in the right spots makes pretty things fit. I thought I wouldn´t be able to use those anymore, but here are my favourite rims on my new favorite truck: --> makes the front 275mm wide and berg rims with the rc4wd-rubber: --> makes the front 270mm wide Both sets of rims have seen the lathe, so those are no stock rim measurements. Uli |
09-14-2010, 06:42 PM | #10 |
Rock Stacker Join Date: Feb 2008 Location: winnipeg
Very nice build....im running a castle sidewinder and a punk dig and it looks nowhere as clean as that rig. Good job
09-24-2010, 01:15 PM | #11 |
did some setup... I used the kit dual stage pistons in the big bores. just drilled them wider. after running 50wt all around i switched back to 30wt in the front, since it felt too stiff. The steering mod is pretty much like the ones around, but I used the stock aluminum plates on the knuckles from two axles. Not zero ackerman but a little better. Little more steering now: This is not supposed to show my sucky soldering but a possibility how to tuck away a sensor cable: I used the long axial shock rodends on the big bores, so by adjusting the shock towers by one hole the rod-end mod ain´t necessary: making room for mattins titanium high clearance links with AX10 rodends: |
