Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Locked Up's XR10 build
Old 08-28-2010, 04:35 PM   #21
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Just placed my order for a 4PKS, some FXRs, Spare RX for my scaler and the Airtronics 94780.
It should all be here by next Friday.
Working on my build up story now....
Locked Up is offline   Reply With Quote
Old 08-28-2010, 11:48 PM   #22
Locked Up's Avatar
I have a roller & I finally got my writeup done:
http://www.noeither.com/rc/tech/xr10-1
I'll get a body on there tomorrow and will take some better pictures.
Old 08-29-2010, 07:11 PM   #23
Moderator Rule Breaker
eric113's Avatar
Looks like every other XR out there.
Have you chosen paint yet ?
eric113 is offline   Reply With Quote
Old 08-29-2010, 07:22 PM   #24
Lol ya wait til the rest of the free world starts getting them. These forums will bloat full with endless XR10 build threads all with pictures of the box.
DRCrawlGood is offline   Reply With Quote
Old 08-29-2010, 09:26 PM   #25
Locked Up's Avatar
I have.
I actually have 2 bodies.
One I got weeks ago and I forgot to clean it out before painting. The paint isn't perfect on it but it still looks good.
For the other, I decided that I'd pay tribute to my drifter color scheme.
All the body pics:
http://www.noeither.com/rc/pictures/...8-29-20101.htm
Here is body #1 fully decked out:
I think if i get some blue or white rings it will look a little better too.
And Body #2 with all the stickers:
You will note one small change I already made. I didn't like the way the front clip went in. I had to drill a hole on the blue/white body and it was still not laying flat. So I drilled another hole in the body mount and turned it 90*. I actually drilled where the mount goes into it's mount and not the top/tip because I thought that would weaken it too much....
I also snapped a few comparisons of the new XR10 bodies to the XC-1's for those that are interested:
Old 08-29-2010, 10:33 PM   #26
Locked Up's Avatar
Just pulled the trigger on some batteries.
http://hobbyking.com/hobbycity/store...0C_Lipoly_Pack
Hopefully, everything will be here by next Friday so I can go beat on this thing next weekend!
Old 08-30-2010, 08:14 AM   #27
Ultimate RC Decals
BOWTIE's Avatar
where are you planning on trying things out? somewhere local to you?
BOWTIE is offline   Reply With Quote
Old 08-30-2010, 09:17 AM   #28
Locked Up's Avatar
There is a place here locally but from the picture I have seen it isn't even as good as my old backyard course. I'll probably do some initial testing there.
I am going to bring it to Barton Springs or Balcones the first chance I get. Hoping for next weekend but it depends on my schedule for work and delivery times on the stuff I ordered. I will let the TXRCRCA guys know when/where so yall can all come and check it out.
Old 08-30-2010, 09:26 AM   #29
eric113's Avatar
I plan on going to baron creek today. I'll let ya know if it dry or not.
Edit I'm sitting at the creek right now and bone dry so we're good to go.
Old 08-30-2010, 06:36 PM   #30
Locked Up's Avatar
Sweet!
I bet it's all nice and cleaned out too.
I wonder how twin falls is looking.
Old 08-30-2010, 08:07 PM   #31
eric113's Avatar
Sweet!
Mostly likely it dry too. It looking like the whole creek dried up finally.
Same area from earlier this year.
Old 09-02-2010, 11:01 PM   #32
Locked Up's Avatar
I got my next batch of goodies in yesterday and spent the night doing my wiring.
My first problem came with my servo being a hair (2mm actually) to long. The CS170 I used for mock-up fit perfectly but the Airtronics hit the motor.
Rather than file down my servo I slapped in some spacers and called it good ... for now. The Alum arm was a no brainer.
Then I noticed the servo lead would be too short to go all the way back. Good thing I have a bunch of random in a box.
This was my first time wiring up dual ESCs and it took a little longer but no rocket science involved. I did place my stuff in the "wrong" locations for a reason, and I'll go over all of that in the next phase of my writeup. For now, I need to get some sleep so I'll just post up a pick of the draft 1 wiring:
Old 09-04-2010, 04:45 PM   #33
Locked Up's Avatar
I ran 2x 2200 packs through it today (my scaler batts).
I told myself I would just stretch it's legs but .... I bound it up enough to stall out my holmes handwound 40ts. Seems to have tolerated my abuse just fine.
I will say this rig is very different for me. I used to run about 50/50 droop, this is maybe 20% droop. My AX10 weighed nearly 10 lbs, this weighs 5lbs 13oz. It is my first MOA and I'm not used to my radio at all ... but already I see the improved capabilities.
Once I get all my electronics sorted out (ESC setup with proper curves, etc) ..... my fellow TXRCRCA members will be in trouble.
I'll post up the few pics I took in the morning. For now, the wife is calling ....
Old 09-05-2010, 09:07 PM   #34
Locked Up's Avatar
A few pics from yesterday:
http://www.noeither.com/rc/pictures/.../9-4-20101.htm
Hopefully I will get to do some testing in Austin next week or weekend. Still waiting on my batteries, weighs and the hotwire for my FXRs.
I have noticed that even with the expo setting on my 4pk I'm not getting the low end control I need from the FXrs.
If the hotwire doesn't fix it I might drop down in pinion and/or to some 55ts.
I also messed around with the links tonight. Still trying to dial in the right wheelbase and weight bias but it is getting there.
Old 09-06-2010, 02:36 AM   #35
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
If you are running my suggested setup I suggest you remove the EXPO. It does not work with the programming. That may be part of your issue actually. Wait until your hotwire comes in and dial in expo using that.
Harley is offline   Reply With Quote
Old 09-06-2010, 04:42 PM   #36
Locked Up's Avatar
I'll give that a shot.
I tinkered with my SCX10 today and boy .... the sidewinder is really, really smooth with the 4pk.
Old 09-07-2010, 04:36 AM   #37
Uli
I really like the sunburst body you painted up. Looks a lot like:
Rock & Crawl
Uli is offline   Reply With Quote
Old 09-07-2010, 08:28 AM   #38
Locked Up's Avatar
Rock & Crawl
Thanks.
I have found those colors the easiest to blend by rattle can...
MRC:
Drifter:
My first Crawler:
Somehow my AX10 narrowly avoided the scheme:
Old 09-07-2010, 09:07 AM   #39
20K Club
Harley's Avatar
I know what you mean, the Castle stuff is butter smooth. Make sure the FXR's have the latest firmware when you get the hotwire. Depending where you buy them they might not be up to date. Some of the updates made drastic changes.
Old 09-09-2010, 03:36 PM   #40
Locked Up's Avatar
I got the new software installed on the FXRs and it is FAR superior to the original setup.
I think with a drop in pinion I'll be perfect. It's hard to compare to my single motor experience and since I am running 40t motors I'm behind the 8 ball. Some testing on the rocks will make the determination but so far it is bench testing very, very well.
I also got my VP slugs in and am tinkering with link & shock lengths.
Hope to get some major testing done this weekend.
