06-14-2013, 12:40 PM | #781 | |
| Re: a tuber Quote:
Benchmark | Walz Hardcore Cycles | |
06-17-2013, 02:54 PM | #782 |
Newbie Join Date: Feb 2013 Location: France Lille
| Re: a tuber
Hy Your new crawler looks realy performant. Clearance and stearing should be a grate advantage. The work you did on your motors is also grate. I also have the Woodoo's and are verry hapy with it. With a total of 1400g I have 60% at the front and 40% on the rear axels and I took Ultra soft for the front and super soft for the rear with Pro-Line 2.2" 2-Stage Oversized Memory Foam. I'm surprised you didn't do your own axels. XR10 is not what you can call simple and reliable. Have fun crawling. Camille |
06-18-2013, 07:36 PM | #783 |
Rock Crawler Join Date: Aug 2011 Location: Perth west oz
| Re: a tuber |
11-21-2013, 01:06 AM | #784 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: a tuber
got a pair of Holmes BR mini i used one 20v 560uF cap http://industrial.panasonic.com/www-...AAB8000CE9.pdf |
11-21-2013, 01:25 AM | #785 |
Quarry Creeper Join Date: Apr 2012 Location: france
| Re: a tuber be careful, they may come very hot |
11-21-2013, 03:20 AM | #786 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: a tuber
What's the little led for? Just so you know there plugged in? |
11-21-2013, 08:46 AM | #787 |
| Re: a tuber |
11-21-2013, 09:08 AM | #788 |
RCC Addict Join Date: Aug 2011 Location: Elkhart
11-21-2013, 09:08 AM | #789 | |
| Re: a tuber Quote:
It is just a red insulation of the cap. Look at other pictures and you will know what I mean. | |
11-21-2013, 10:49 AM | #790 |
| Re: a tuber
you guys are right , looks a bit like a small led |
11-21-2013, 11:30 AM | #791 |
Rock Crawler Join Date: Oct 2012 Location: Trail B.C.
| Re: a tuber
Just read this whole thread from start to finish and I can concur with the others. Insane in the best possible way. Sweet work and innovative thought. I have noticed your upper link mounts on the axles. With the disappearance of VP in the XR10 market (or the partial disappearance thus far) there would be a market for the style of link mount you use. I specifically mean this style that you had used in the past. I say this style as I noticed you have 2 styles for the simple fact that there are those that may be unwilling to grind down their cases or just not able to. This makes it an easy bolt on for the likes of those. I also like the idea of the load being spread out through the whole top rather then just the center tab. Pretty sure there would be some interest in either method though. |
11-25-2013, 08:44 PM | #792 |
| Re: a tuber
Geez Christian, I was beginning to think you fell off the earth. It's good to have you posting again |
11-26-2013, 01:11 AM | #793 |
Quarry Creeper Join Date: Jan 2007 Location: Italy
| Re: a tuber It is the first time I see such an innovative solution for the servo and I felt in love with it. It doesn't seem to complex to reproduce too, so may be I will try. I would like some information on how you modified the servo. Don't know MKS servo, do they have a metal case ? Did you have to make new holes and tap them for bigger screws in the gear cover ? Besides MKS servo are not easy to be found... did you buy it online somewhere ? Thanks Filippo |
07-12-2014, 09:52 AM | #794 |
| Re: a tuber
itīs still alive |
07-13-2014, 08:32 AM | #795 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
| Re: a tuber
Where have you been for 8 months!!!
07-13-2014, 11:41 AM | #796 |
Newbie Join Date: Oct 2010 Location: Alicante
| Re: a tuber
Nice to meet you again. Never die
07-13-2014, 11:46 AM | #797 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
| Re: a tuber
Welcome back. We've missed you |
07-13-2014, 06:41 PM | #798 |
| Re: a tuber
I just saw a ghost! Congrats on the win Christian! |
07-15-2014, 10:15 AM | #799 |
| Re: a tuber
Thank you guys thereīs not much time for the hobby now only some minor changes at the rig i will post later after watching pics like this Holmes Team, Pro, and Custom motor Tech for awhile i think i will make some new motor cans hope to get a bit more torque and less rpm |
07-15-2014, 10:50 AM | #800 |
| Re: a tuber
Still planning to use the 7 slot arms? If you send a dxf of that view I can run it through FEMM to see how the saturation levels hold, unless you have already done it! We will need the armature drawn in it too for an accurate model. Very slick thinking there. I've thought about varied back iron a lot and never wanted to share it because I couldn't figure out an affordable way to make it without an extrusion. You should get a nice boost in your torque efficiency VS a straight 1mm can, and you won't have the full weight gain of a 2.5mm can. Glad to see somebody departing from the very bad practice of just taking off back iron to save weight, it ain't worth it!! |
