07-15-2014, 10:55 AM | #801 |
Quarry Creeper Join Date: Feb 2009 Location: Warwick
| Re: a tuber
John, would screwing a couple of steel "C"s to the OD of a thin can have a similar effect?
07-15-2014, 12:17 PM | #802 |
| Re: a tuber
Yes it would. You can also feel the same effect by getting a spinning motor closer to a steel object. If the back iron is too thin the RPMs will drop as it gets closer. Admittedly, even our pullers with thin Neo magnets saturate 068 wall cans, although the power density is still better than using ceramics or cobalts and we found a pretty damn good balance of too much or too little. The next revision will put more back iron into the proper spots and take weight away from other areas to compensate. The biggest danger from running too thin of back iron is that magnets will demag easily without it. I have read that others had problems destroying neo magnets on thin wall cans, but they dismissed it as inferior materials instead of just bad design. Christian has the smarts to figure it out! Good to see you back around, always cool stuff. |
07-20-2014, 07:15 AM | #803 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: a tuber
just some pics i use 800mah packs now some tiny springs Motors and cvdīs work great |
07-20-2014, 07:45 AM | #804 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Re: a tuber
What is your rtr weight now?
07-20-2014, 07:48 AM | #805 |
| Re: a tuber |
07-20-2014, 07:52 AM | #806 |
| Re: a tuber |
07-20-2014, 10:35 AM | #807 |
| Re: a tuber |
07-21-2014, 07:43 AM | #808 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: a tuber
A thing of beauty and a joy forever. J |
07-27-2014, 04:25 PM | #809 |
Rock Stacker Join Date: Aug 2011 Location: france
| Re: a tuber
congrats for your first place at the french nats my friend !!! you rocks |
07-28-2014, 07:09 AM | #810 |
RCC Addict Join Date: Jun 2007 Location: Finland
| Re: a tuber
Congratz Christian! Awesome job! |
07-28-2014, 08:23 AM | #811 |
Pebble Pounder Join Date: Dec 2011 Location: franįe
| Re: a tuber
congrats for your first place at the french nats |
07-28-2014, 12:34 PM | #812 |
Pebble Pounder Join Date: Jul 2011 Location: Germany
| Re: a tuber
Congrats for the first place Christian Awsome driving skills |
07-28-2014, 02:39 PM | #813 |
| Re: a tuber
Thank you guys, was just Great to meet you all |
07-28-2014, 03:11 PM | #814 |
Quarry Creeper Join Date: Feb 2011 Location: Germany
| Re: a tuber
Congrats |
07-28-2014, 09:23 PM | #815 |
Quarry Creeper Join Date: Dec 2013 Location: FRANCE
| Re: a tuber
Hi, congrats for your first place and all lesson Saturday...........
07-30-2014, 11:03 PM | #816 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
| Re: a tuber
Looking good,,, That is a extremly low weight,, To low for me,, my reptile is like 1700,,without the rcbros weighs I put on,and that is little over 100g on each side,, |
04-17-2015, 01:41 AM | #817 |
| Re: a tuber
if someone wants to try the chassis egressor-chassis.dwg (0.03 MegaByte) thats the dwg file of the chassis and a dxf egressor-chassis.dxf (0.18 MegaByte) chassis plates should be 2.5mm unidirectional carbon cap should be 3mm polyamide , there is a high and a low version , i prefer the high for better roll-over-ability and the parts in pdf felsenfest_xr10_egressor-chassis Model (1).pdf (0.01 MegaByte) plates felsenfest_xr10_egressor-chassis Model (2).pdf (0 MegaByte) low felsenfest_xr10_egressor-chassis Model (3).pdf (0 MegaByte) high felsenfest_xr10_braces Model (1).pdf (0.01 MegaByte) braces Last edited by EGRESSor; 04-18-2015 at 01:34 AM. |
04-17-2015, 02:29 AM | #818 |
| Re: a tuber
i used arrow shafts for the links X7 Eclipse - High-Precision Alloy Target Arrows | Easton Archery big radius bends are possible , itīs high strength aluminium , acts like spring steel , i never bent or broken one in the last 2years |
04-17-2015, 05:16 AM | #819 |
Newbie Join Date: May 2012 Location: Germany
| Re: a tuber
Thanks Christian for showing the chassis datas! This is the best chassis i ever run. I used for the rear links this : Easton XX75 PLATINUM PLUS Aluminium Schaft Last edited by efdeluxe; 04-17-2015 at 05:18 AM. |
04-17-2015, 07:35 AM | #820 | |
| Re: a tuber Quote:
David's Berg - Seite 5 - enRoute Berg - Rockcrawler.de and another one from Germany Jenzzz Felsenfest V1 - Seite 2 - enRoute Berg - Rockcrawler.de and another one from Germany Wie die ***** zum Berg kommt oder wo ist die Grabbeilage ??? - Seite 5 - enRoute Berg - Rockcrawler.de and another one from Germany bluetiful - Seite 2 - enRoute Berg - Rockcrawler.de | |
