04-17-2015, 07:44 AM | #821 |
Newbie Join Date: May 2012 Location: Germany
| Re: a tuber
You are right, Christian. The reason is, my english isnt so good, i think and i dont wanna to shame oneself... Thanks for linking David |
04-18-2015, 09:34 AM | #823 |
Quarry Creeper Join Date: Feb 2012 Location: MARTINIQUE
| Re: a tuber
Hi Christian, that's realy nice to share your chassis here , i like the squidless ... I was working on my stingray UGC trying to lower it and wide upper fixations, then i found your post !!! Now i have to realise it, hope to see you at the Big this year again Olivier Last edited by OLI972; 04-18-2015 at 10:24 AM. |
04-18-2015, 01:38 PM | #824 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: a tuber
happy building Olivier iīm not sure about the BIG this year , itīs before the Holidays but i will try to .... |
04-19-2015, 08:52 AM | #825 |
Quarry Creeper Join Date: Feb 2009 Location: Warwick
| Re: a tuber
Christian, on the Easton arrow shafts... are there different diameters? I can't find that info listed anywhere on the Easton site or anywhere else on the web. Do you have the shaft number, is it a 1514? John |
04-19-2015, 10:28 AM | #826 |
| Re: a tuber
the first 2 digits are the OD in 1/64" , the last 2 digits are th wall in 1/1000"
04-19-2015, 11:21 AM | #827 |
| Re: a tuber
.... Of course ...and you are using ~6.0 mm shafts with ~0.35 wall? Same thing for the rear uppers, or ~4.75 mm 7075? |
04-19-2015, 11:19 PM | #828 |
| Re: a tuber
my rear lowers are 1614 eclipse w. glued in 1413 jazz rear uppers 1614 eclipse front lowers are 5x0.5 titanium tube (because the welded on shock mounts) front uppers 1413 jazz |
04-20-2015, 12:15 AM | #829 |
| Re: a tuber
just because some mail requests , the plates can be made from woven carbon too , delrin or lexan will work too for the cap my choice is the uni carbon for the plates , itīs just stronger than the woven hereīs a link to a comparison Uni-Directional Vs. Woven | Oribi Manufacturing the polyamide for the cap because the impact strength and abrasion resistance |
04-20-2015, 07:01 AM | #830 |
| Re: a tuber
Just to be clear, are the 1413 Jazz full length in the 1614 Eclipse? So the rear lowers are in effect double wall? Are you gluing Ti 4 mm thread inserts in each end? Glue with Loctite retaining compound or some sort of epoxy? j |
04-20-2015, 08:05 AM | #831 |
| Re: a tuber
yes, full length double walled for the rear lowers i used 7075 M4 socket head cap screws , head turned down to 4.9mm and cutted M5 outside thread the ID of the 1413 fits perfect for M5 thread , i use thread forming taps because it didnīt cut the grain flow , a thread cutting tap will work too the rear uppers are slightly pressed in a triangular form like i did here a tuber M5 formed in and so on i used high strength Loctite for the threads |
04-21-2015, 02:12 PM | #832 | |
Pebble Pounder Join Date: Sep 2008 Location: Vancouver Island, BC, Canada
| Re: a tuber Quote:
Cheers mate! This is such an interesting thread to read going back 5 years and to see the changes to the scene. It seems so suttle in the moment but when you look at the larger picture the changes are really interesting! Earlier on someone was said to be telling you your +5 lb rig was "lightweight" | |
04-21-2015, 02:16 PM | #833 |
| Re: a tuber
Also we seem to share the same idea on springs |
04-29-2015, 01:49 AM | #834 |
| Re: a tuber
result of the comp last weekend 1. Lauf DE Cup - Ludwag 25.4.2015 - Seite 5 - Wettbewerbe Crawler nur 1.9/2.2/Superclass - Rockcrawler.de not to bad for 8 months of abstinence in crawling |
04-29-2015, 05:59 AM | #835 |
Pebble Pounder Join Date: Nov 2012 Location: Bavaria / Germany
| Re: a tuber
You have the link with the results after 4 and 5 courses, here are the total results: Ergebniss DE-Comp Ludwag Hope for a good fight soon at Supercrawl Last edited by Snatch; 04-29-2015 at 06:01 AM. |
04-29-2015, 07:22 AM | #836 |
| Re: a tuber |
05-20-2015, 06:27 PM | #837 |
| Re: a tuber |
05-20-2015, 11:22 PM | #838 |
| Re: a tuber
welcome to the family Oli itīs a beauty Last edited by EGRESSor; 05-21-2015 at 04:56 AM. |
08-17-2015, 04:01 PM | #839 |
| Re: a tuber
Very curious about the internally splined "spools" that you used for the axle builds, and also the splined axle shafts. Were those something that you made or are they an available part from an outside vendor? |
09-12-2016, 01:23 AM | #840 | |
| Re: a tuber Quote:
