09-10-2010, 02:39 PM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: _________
| BentKa's XR10 YTC Secret Agent
Let me just start by saying that my original plan was to do a rebuild of my Bully Moonbuggy, but since I ordered the XR10 same day it was released and it turned up just in time for my rebuild I just couldn't resist any longer 2011 spec list: Chassis: XR10 T1E Rockshow Forward Bias Axels: Axial XR10 Shocks: Losi 4" Crawler Shocks shortened with shorter 0.9 damper housing and 1.0 rod. Rod end modified. Links: Lunsford Titanium Lower & Upper, T1E High Clearance Lower Rear Steering tierod: Chaotic Crawlers Titanium Knuckles: Vanquish 0 ackermann Knuckle weights: Vanquish Transmission cases: Vanquish Motor plates: Vanquish C-hubs: Vanquish Rear lockouts: Vanquish Front link mount: Vanquish Front servo plate: Axial Carbon Rear link mount: Hot Racing Rear servo plate: Axial Carbon Gears: Axial machined lightweight transmission gears + titanium shafts Bearings: Full Boca Green Seal set Motors: 2 x Team Br00d Limited Edition 35T Double Wind Servo: Hitec HS-7980TH at 7.4V ESC: 2 x Tekin FXR BEC: Castle 10A Radio: Futaba 4 PK Super w/R614FF Battery mount: BigRon Carbon Batteries: 6 x ThunderPower 3S 850mAh 65/130C Rims: 1 set 1" wide VP SLW V6 + 3 sets of 1" wide VP SLW V3 Tires: Losi Boss Claws Red, HB Sedona White, HB Rover White, HB Rover EX Pink Foam: Nova 5.25" for Claws and Rover EX, Nova 5.5" for Sedona and Rover White Bent Last edited by Harley; 03-22-2012 at 07:20 AM. Reason: Updated specs for 2011 season |
09-10-2010, 02:46 PM | #2 |
Axels built and Torquemasters installed: The "Monster" HS-7980TH Electronics installed on the skidplate. 2 x Tekin FXR CC 10A Bec Futaba R604FS-E with internal antenna Bent |
09-10-2010, 03:03 PM | #3 |
Installed lower links (temporary uppers) and shocks: Bent |
09-10-2010, 03:23 PM | #4 |
"HOLLYWOOD" Join Date: Dec 2008 Location: Miami
Wow looks really good cant wait to see it with wheels mounted
09-10-2010, 03:56 PM | #5 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
Sweet a bully guy that knows what it means to have an unbreakable rig. Looking forward to hearing your feedback on strength compared to ur old setup. I don't want to change my driving style too much when I get mine lol
09-10-2010, 04:10 PM | #6 | |
My lightweight Bully axels and V6 XVD has taken A LOT of beating and just brushed it off every single time. I will probably drive a bit more careful in the beginning nervous of breaking something Bent | |
09-10-2010, 04:18 PM | #7 |
| Here you go With VP SLW V3 and Losi Boss Claws stuffed with Nova 5.25" Double Deuce foam. Mandatory flex shot: A better view of the geometry: Total weight RTR with 136g added to each front wheel. No extra weight in the rears. sKinz and panels will add app. 50-60g. Bent |
09-10-2010, 08:58 PM | #8 | |
X2... I'm already ordering extra Axle Tube/Cases for back ups. | |
09-11-2010, 12:42 PM | #9 |
09-11-2010, 12:50 PM | #10 |
Here are some pictures of the completed rig with sKinz from Neal at Freqeskinz Final weight ready to race with panels and sKinz: I'll post some pictures of the matching 4PK sKinz later Bent |
09-11-2010, 04:36 PM | #11 |
Rock Crawler Join Date: Aug 2008 Location: Portland, Maine
Very tasteful combo of goodies man. |
09-11-2010, 10:55 PM | #12 |
Rock Crawler Join Date: Jan 2010 Location: Arvada
Sweet Crawler. I knew it wouldn't be long before someone threw them axles on the T1E chassis. I've been thinking that's what I wanted to do from the start Let us know how it does, i'm sure it'll be great! |
09-12-2010, 02:59 AM | #13 | |
After running this chassis on my Bully this year I just had to see how these axles compared. First impression are good. Not great.....yet. Need some fine tuning and quite possibly MORE weight (up front). Ran 3 courses in round 3 of the championship yesterday and ended up fifth. The courses were wet (due to rain earlier) and slippery as h..l. This comp site is slippery even in the dry and were quite the challenge at times in the wet. Rig was quite stable and performed OKAY on the choice of tires for the day, Rover EX and Boss Claws. I'll go out today and test at our local spot with some different weights and tires and see if I can get this thing as dialed as my Bully Moonbuggy A few from yesterday: Bent | |
09-12-2010, 04:24 AM | #14 |
RCC Addict Join Date: Jun 2009 Location: California
what offsets front/rear? Very clean build...Needs to be in a magazine... On my .7s I'm running two stacked full wraps..Seems to be better now.... |
09-12-2010, 04:44 AM | #15 |
Pebble Pounder Join Date: Jan 2009 Location: Helsinki, Finland
I'm looking forward to seeing this, and all the other Norwegian moneyman-crawlers at the Nordics next year. We need to do something for our trucks to beat you..
09-12-2010, 05:29 AM | #16 |
Quarry Creeper Join Date: Jan 2010 Location: UAE in the GCC
this T1e moonbuggy looks really clean ..... like it was built and assembled effortlessly .... cheers |
09-12-2010, 06:25 AM | #17 | ||
And building R/C vehicles for 25 years + does make up for some trial and error Bent | ||
09-12-2010, 06:30 AM | #18 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
Hello, nice T1E XR One question might be allowed, how do the Boss Claws do underr wet conditions? Greetings Frank |
09-12-2010, 06:50 AM | #19 | |
They actually do quite well under wet conditions, BUT they do need to stay clean to work properly. As soon as you pick up dirt they tend to loose traction in the wet. However they clean out really well with just a little throttle and wheel spin. First impression is that they are a bit more sensitive to the surface being clean than the others with larger deeper lugs. This tire is not as versatile as a Sedona or Rover tire but under the right conditions they work REALLY well Bent | |
09-12-2010, 06:59 AM | #20 | |
Thanks I'm running 475 hubs in the front and 600 in the rear. This puts me at 11.25"ish in the front and 10.75"ish in the rear with Boss Claws on 1" SLW. I don't like it too narrow. With this setup I'm almost exactly where my Bully was Front: Rear: Bent | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-xr10/269275-bentkas-xr10-ytc-secret-agent.html | ||||
BentKa's XR10 T1E Rockshow Signature Series | This thread | Refback | 10-07-2011 12:35 AM |
