Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: The generals XR10
Old 12-18-2010, 01:53 PM   #21
Originally Posted by murderface View Post
best think ive seen for motor protection is
i think ugc is makin them i'd ask dickyT
plus they go with your polished bling
I beleive CrazyOrigin made them for DickyT.
But yeah, those things are pretty nice.
shelby is offline   Reply With Quote
Old 12-18-2010, 02:02 PM   #22
i dont know where theyre comin from i saw em on dt's build thread and all i know is theyre badass too bad they wont work for me for reasons im not at liberty to share
murderface is offline   Reply With Quote
Old 12-23-2010, 09:29 AM   #23
I actually ended up putting on Monster energy cans for motor protection. I went wheeling out at Indian Rock Park in Berkeley yesterday after work, that place is pretty sweet! Lots of different lines to take.
I finally painted the body, I think it turned out pretty good
I found someone selling a set of 1" SLW V1's, black on black and couldn't pass up the deal. I can't wait to get them
generalee7 is offline   Reply With Quote
Old 12-23-2010, 09:39 AM   #24
its got a mohawk!
Old 12-23-2010, 09:46 AM   #25
nice looking rig, love the color sceme! deans directly soldered to the punk dig is a really good ideahows that workin for ya?
longviewskyline is offline   Reply With Quote
Old 12-23-2010, 09:54 AM   #26
Works great! I saw it somewhere else and had to copy the idea since it simplifies the wiring a bit and I'm all about that
Old 12-23-2010, 01:21 PM   #27
That thing is Storm Trooped out. Reminds me of my LCC I had. Nice lid
Jeepkid is offline   Reply With Quote
Old 12-23-2010, 03:05 PM   #28
Thanks! I guess it is the storm trooper lid
Old 12-23-2010, 03:26 PM   #29
big supporter of the storm trooper look id like to go white whith a neon green splatter job on my xr lid
like thisName:  175218_hi.jpg
Old 12-24-2010, 01:11 PM   #30
You said you were having trouble with your front tires rubbing your shocks....
Mount the shocks to the inside (inboard) of the shock mount on the axle instead of in the center of it where you have them.
You might have to go with some longer rod ends, or space your spring cup up a little to keep from hitting the gear box, but it gets you more turning and flexing with less tire scrub.
Harvo is offline   Reply With Quote
Old 12-24-2010, 01:22 PM   #31
Originally Posted by generalee7 View Post
I'm getting some alum box lower links like you have. Did you need to make any adjustment to shock mounting or anything like that to get them working with good clearance?
Although overkill, I'm going to run all box links....aesthetics more than anything else.
JustinThyme is offline   Reply With Quote
Old 12-24-2010, 02:03 PM   #32
You know, I was thinking about spacing the spring cups up. For now, the tires are staying out of the shocks but I'd still like to get them mounted inboard like you said; just need to pick up some longer M3 screws
Old 12-24-2010, 02:06 PM   #33
No modifications needed to run the machined links. I wanted to run the 30* bent uppers for cost reasons and you seem to have a little bit more clearance to fit batteries and/or a longer electronics tray, if you so choose.
Speaking of electronics tray, I got rid of all the stock Axial stuff and made a flat sheet of clear plastic that bolts on where the stock one does. Fits great with a couple risers! There is a little bit of interference where the lower links contact the tray but that's at full compression.
Old 12-24-2010, 02:21 PM   #34
After digging around my bags of parts, I found some stainless bolts, aluminum spacers and cone washers that will work Bling bling yo!
This setup has plenty of clearance in all directions. I'm convinced this is the absolute best setup utilizing factory components (plus longer M3 screws)
Old 12-24-2010, 03:29 PM   #35
Will you be comping this?
Old 12-24-2010, 03:29 PM   #36
I didn't use either kit tray. I cut a piece of .040 lexan which runs from the back of the baseplate to about 1/2" shy of the bend in the upper 30* links, and mounted it straight to the baseplate. Novak M2Dig mounted in the rear, receiver mounted on it's side in the middle, and the battery forward. Currently using a Losi square 2S 600 LiPo designed for the Losi Mini Crawler. It can fit batts up to about 2 1/2" long.
In this pic, the rcvr is mounted flat, but I put it on it's side to give me more battery options. Very neat and clean solution, much lower CG than stock, and it was cheap and easy to do. I put 4 washers on each side to match the tray spacers at the shock mounts, but have since replaced them with a single 4mm lock collar/spacer (much easier to work with than 8 washers when making changes!) per side.
Old 12-24-2010, 04:26 PM   #37
Probably not. Just a very capable hobby crawler
Old 12-25-2010, 01:06 AM   #38
Looks like the rod end on your shock is cracked. Better fix that before any comp you may be attending. Hate to break that on gate 1.
calikingcrawler is offline   Reply With Quote
Old 12-25-2010, 01:11 AM   #39
That happened due to me tightening the rod end past the threads on the shaft. I'm not worried about it since I doubt I'll be running any comps any time soon with school starting in a month.
Old 12-25-2010, 09:36 AM   #40
Got a little video yesterday
http://www.youtube.com/watch?v=QNakT6VIFbc
