06-22-2011, 05:01 PM | #101 |
Rock Crawler Join Date: Jan 2011 Location: Hartford City, Indiana
Perhaps I missed it somewhere in the thread, but are the BJ links longer or shorter than the XR10 ones?
06-22-2011, 05:26 PM | #102 |
I wanna be Dave Join Date: Oct 2007 Location: 801
Bj links are shorter than stock. Pm sent! |
06-23-2011, 10:09 AM | #103 |
Quarry Creeper Join Date: May 2011 Location: Salt Lake City
Links are in and damn do they make this truck better! Killer vendor. Thanks for all your help! And top notch quality from a top notch guy. |
06-23-2011, 12:14 PM | #104 |
06-29-2011, 11:17 AM | #105 |
| Saw you got the links back in and decided to go ahead and order. It'll be fun making them work with the Progress Chassis! |
06-30-2011, 12:34 AM | #106 |
07-01-2011, 01:06 AM | #107 |
Quarry Creeper Join Date: Dec 2010 Location: Earth
07-01-2011, 09:42 AM | #108 |
07-01-2011, 01:21 PM | #109 | |
We are pretty confident that the BJ4 Lowers will work with the progress chassis. However at the time we don't have any upper links that will work with this chassis. If the demand is there anything is possible!! | |
07-18-2011, 06:02 PM | #110 |
| All Links are back in stock... All pre-orders went out either Saturday the 16th or Monday the 18th. Thanks again for all the Support |
07-18-2011, 10:12 PM | #111 |
Quarry Creeper Join Date: Jan 2008 Location: Citrus Heights
I receiced my lower set today and they work great. The fit was perfect and the size helped make the travel smoother than with the other lowers I have been running. Thanks |
07-19-2011, 09:24 AM | #112 |
That's great to hear!!! Thanks for posting up and lettin us know! We love hearing feedback from our customers!!! |
07-20-2011, 02:11 PM | #113 |
Rock Crawler Join Date: Dec 2008 Location: With the ATL Crawlers
Have you got straight lowers for the front to replace the stock links? I'm wanting to keep my shocks mounted to the lower links
07-21-2011, 11:19 AM | #114 |
We could make you a set. Everything we have is already bent. Shoot me a pm if your interested. |
07-24-2011, 05:17 PM | #115 |
Rock Crawler Join Date: May 2011 Location: SoCal
My link install on a dead-stock XR10 didn't quite work out. You wrote: "The rears is where you have to change it up a little! Instead of using all 4 short rod ends on the uppers, you will instead use... 2 long bent and 2 short bent on both the uppers and lowers! This moves your rear motor up and out of harms way." Did that and got a LOT of clocking on the rear motor. At full height the links are nearly touching the top of the motor and they make contact early in the stroke. Obviously I can correct this by changing to short/short links on the upper links and even long/long on the lowers if necessary. But I'm wondering why it didn't work out straight out of the box? Are some XR10s different than others -- or your links not all the same? Your Post #1 photos don't have motors installed. How much clearance link to top of the rear motor do you get with stock (4") shocks in the Axial-recommended holes? IE a totally stock XR built straight to the book. Photo at max height: |
07-24-2011, 08:09 PM | #116 |
Typically the short rod end on the rear upper should be on the axle end of the link. The shorter end will bring the bend on the link closer to the axle where it's supposed to be. All the links are identical. There should be no reason yours won't work as well. What do you mean "they make contact early in the stroke"?? If they are contacting the motor, the short rod end should fix that. |
07-24-2011, 08:14 PM | #117 |
You need to shorten the uppers and then the motor will not hit them. The motor doesnt need to be that high. Lower the motor and you will lower the center of gravity too |
07-24-2011, 08:24 PM | #118 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
He also needs to get rid of the axial rodends. Pick up some revo and jato ends |
07-24-2011, 11:34 PM | #119 | |
Just to cover the remote possibility that I got the wrong links in the package, can you tell me what the eye-to-eye lengths are supposed to be? I'll get a set of digital calipers on them when I remove them to swap the ends. | |
07-25-2011, 07:38 AM | #120 |
Our website only list a Recommendation and not exactly what you must do. We have used those links personally and sent out several with no issues. If you feel the motor is clocked too high we recommend going with 2 short bent rod ends. We designed these links around using the Axial rod ends because of all the different sizes it should give you endless options. Could you PM, email or post some pictures at full flex?? I would like to get a better idea of where it is hitting so we can solve your issue. thanks |
