05-01-2011, 07:45 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: Frisco
| XR10 motor skids courtesy of Walgreens...
and a couple minutes on the bandsaw: 1" diameter container snap fits into place although I might hit one end with a thin strip of servo tape. |
05-01-2011, 08:54 PM | #2 |
Rock Crawler Join Date: Aug 2008 Location: Somewhere in the Sierras.
Nice, thanks for the tip. I just went and made a set from similar material. |
05-02-2011, 06:06 AM | #3 |
I do the same thing on my motors. |
05-02-2011, 06:27 AM | #4 |
I wanna be Dave Join Date: Jul 2006 Location: Moscow Mills MO
Couple of minutes on the bandsaw? You need to change your blade Good job bro, I use 5hr energy bottles |
05-02-2011, 07:23 AM | #5 |
Nice...just what I needed...a little more orange to replace the white skids I have now...THANKS!
05-02-2011, 07:23 AM | #6 |
They look good, though you may want to extend it out a little further to protect the endbell |
05-02-2011, 08:38 AM | #7 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Awesome tip, thanks! |
05-02-2011, 10:26 AM | #8 | |
I'm glad some of you found the suggestion helpful! Truer than you know Okay, so it took about 30 seconds on the bandsaw and 90 seconds of pulling the melted plastic off the edges and cleaning them up a bit Quote:
That's a really good idea! I made the first one a little wider but on my current motors I have the motor wires coming off the tabs at 90 degrees so they hit cover. I have new motors coming and I'll solder the wires up a little better so I have more room and can protect the endbells next time. | |
05-02-2011, 10:47 AM | #9 | |
here is the endbell cap on my CO motor guard\battery mount as example | |
05-02-2011, 10:59 AM | #10 |
05-03-2011, 05:11 AM | #11 |
RCC Addict Join Date: Jun 2007 Location: Indian Village Pontiac
Been using the meds bottles for a long while now(In fact I posted this tip in another thread several weeks ago), And I leave the bottoms on the bottle to protect the end bell and brush hood. The one thing I did find is that unless you cut open the vents in motor can, your motors life will be shortened by this method(I know, been there) So the point is,,, If you run ANY motor skid be sure the motor vents are open and free to circulate air to allow cooling and evacuate metal/copper/carbon particles,,,,,, |
05-03-2011, 09:50 AM | #12 | |
Thanks for the tip on the venting! | |
05-03-2011, 05:18 PM | #13 |
Quarry Creeper Join Date: Sep 2010 Location: Port St Lucie
05-05-2011, 09:20 AM | #14 |
Pebble Pounder Join Date: Oct 2010 Location: Jewel of the Sierra
Ditto on the vents for the motors!
05-05-2011, 11:50 AM | #15 |
Rock Crawler Join Date: Mar 2008 Location: Grand Rapids
i used a really cool plastic with an adhesive backing that you apply with a heat gun works great
05-14-2011, 09:24 AM | #16 |
Pebble Pounder Join Date: May 2008 Location: Mobile, AL
good idea, you should stick a novak sticker on them and they would look factory! LMAO Jake |
