07-13-2011, 08:32 AM | #1 |
Rock Crawler Join Date: May 2011 Location: SoCal
| Radio choice
So it seems like the big dogs are typically running 4PK's. I've read in threads that the 4PL also works for dual ESC's, and is what, half the price? Me, I'm starting with a DX6i twin stick because I have it. But if I decide to buy a pistol grip, what would be the reason to spend the extra money for a PK versus a PL? I'm sure it has more bells and whistles -- but does it actually do something on the rock I can't do just as well with a PL? |
07-13-2011, 02:02 PM | #2 | |
TN State Champ 11,12,13 Join Date: Oct 2008 Location: KTM Talk.com
More Bells and Whistles | |
07-13-2011, 02:18 PM | #3 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
4pl or 4pk. Every other choice is the wrong one |
07-13-2011, 02:48 PM | #4 | |
RCC Addict Join Date: Jul 2009 Location: Santa Rosa, CA
I say stick with the dx6i. | |
07-13-2011, 03:37 PM | #5 | |
My twinstick is "ground-modified" -- both sticks return to center position. I kinda want to keep steering and throttle the same as my planes, throttle on left stick, up & down (for reverse) and steering on right stick, side to side. I assume people use a third movement to slow or stop the front or rear motors for dig. How is yours set up? | |
07-13-2011, 09:55 PM | #6 | |
I have a 6EX and it is just not even possible to flip the switches on it faster than on a 4PK. Even the TOP stick radio drivers switched to pistol grip radios in order to be more consistent. A stick radio does not belong on a 2.2 rig. | |
07-13-2011, 10:00 PM | #7 |
There are many differences between the 4PL and 4PK. I won't/can't list them all but here is a few. The dig is operated differently. The 4PK does it with separate buttons which is nice because you can cycle faster and know you are not going to accidently hit the wrong dig. The mixing values are displayed on the main screen on the 4PK The 4PK has two programmable mixes to be used for whatever you want. The 4PKS and 4PL both have 4WS programming The response time is faster on the 4PK The RX's are much cheaper on a 4PL There are more but it is hard to list it all. |
07-13-2011, 10:18 PM | #8 | |
Pebble Pounder Join Date: Jan 2011 Location: Frisco
Or if you really want to suck that suspension down (and take a minor penalty) you can always move the front stick forward and the rear stick backward for some serious squat. Of course most of you guys would still blow me away regardless of the radio--but stick radios are a lot of fun! | |
07-13-2011, 10:21 PM | #9 |
Thanks Harley. I'm not needing a full list of differences. Just whether the 4pl will not put me at a significant comp disadvantage. The price difference is significant for those on a budget.
07-13-2011, 10:21 PM | #10 | |
Newbie Join Date: Oct 2009 Location: Mt. Carmel
07-13-2011, 10:52 PM | #11 |
Pebble Pounder Join Date: May 2011 Location: Fort Bliss
I have the same radio as JWR and must say I really enjoy it. One mix is set so the left stick controls both motors and my right controls the steering. At the same time if I want to speed up or slow down the rear motor I can use the right stick to override the left stick. At the flip of a switch I can control the motors independently as well. If I was to convert the reared for rear steer I would have even more options.
07-13-2011, 10:55 PM | #12 |
All said though, I think you can't go wrong with either of those pistol grips. If you can swing it I would go for the 4PK.
07-13-2011, 11:33 PM | #13 |
| I understand you want people to buy futaba's $500 radio. But i'll make a video and show you how mine is set up.
07-14-2011, 12:07 AM | #14 | |
The 4PL at the least is just a much better option as far as consistent driving with a 2.2 rig. | |
07-14-2011, 12:21 AM | #15 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
At $200 USD, you cant go wrong with the 4PL. I am super happy with it. I use it for my super, and will use it for my XR. Casey |
07-14-2011, 08:28 AM | #16 | |
Rock Crawler Join Date: Aug 2008 Location: Somewhere in the Sierras.
Not to insult you Harley but you come across at times as the end all authority on everything RC and no one can have a better idea or option than you. Just my observation of your posts...I'm sure you could careless about what others think of you. I just had to voice my feelings. BTW I love my 4PL but I won't say it's the only or best radio. Find whats best for you!!! | |
07-14-2011, 08:36 AM | #17 | |
But I'll still try my DX6i first since I have it. Who knows? I might like it. I'd like it more if there was a good thread on how to set it up. I'm pretty sure I know how to install batteries and turn it on. The rest I'll have to figure out. | |
07-14-2011, 09:20 AM | #18 | |
I wanted to run sticks before, thats when I did a ton of experimenting. Futaba has then also sent me a 6EX to work with so I can help with support. I have worked with all the possible programmings now, both throttles on one with no switch for dig, seperate sticks when mixing is turned off, switches with both mixes on one stick, etc. Anyway you do it you can't cycle the dig on and off faster than the quick hit of the 4PK button. That was the discussion. The reason the 4PK and 4PL are so popular is because of the ability to have a consistent feel. It is impossible for 99.9% of people to be able to feed power into both motors evenly at a different rate. The stick may give you more infinite control variations but you can't do it nearly as consistent. This is why the pistol grip radios dominate all classes now. | |
07-14-2011, 02:07 PM | #19 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
Would I be correct in saying more use the 4PK because it was on the market before the 4PL ...I LOVE my 4PK |
07-14-2011, 02:21 PM | #20 |
| Actually I don't know. We have had huge success with the 4PL. With the price point being below a DX3r and it having an extra channel and just being a better radio for crawling it has sold fantastic. The 4PK help thread was started in 2008, the 4PL thread isn't even nearly a year old and it's almost as long already. That's just a quick measuring stick.
