10-10-2011, 09:24 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: ca
| XR10 Overdrive front axle?
Hi all, I just want to see if anyone has tried this and what their experience was like. I'm running my XR10 with a single sidewinder esc and dual 55t motors. I was wondering if I could get a little more crawling performance out of this temporary setup by over driving the front axle by a tooth or two. I eventually will get another ESC or maybe just a dig unit. Thanks |
10-10-2011, 09:35 PM | #2 |
Yes...that will be a good improvement when running a single ESC.
10-10-2011, 09:39 PM | #3 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
Yes. That's actually common in people with dual ESC's. A little over drive is nice at times. But sometimes, it hurts on an MOA in my opinion. With the clod stall factor, an over driven front end on a hill will amplify clod stall. Sometimes you dont want clod stall.
10-10-2011, 09:48 PM | #4 |
Good point there too...
10-10-2011, 09:49 PM | #5 |
I'm getting more clod stall than I want right now, and I think the fix is going to be a second esc. My motors aren't the best either. I'm using the Axial 55T motors. I think I'll pick up some 55T integy motors. I'll report back with my results on the gear up. Thanks for the quick replies |
10-10-2011, 10:58 PM | #6 |
Rock Crawler Join Date: Aug 2010 Location: Surrey BC
a slight gear up pinion in the front will work well for the front as a cheap fix for now with one esc till your budget goes up for other stuff
10-11-2011, 11:42 AM | #7 |
Newbie Join Date: Sep 2011 Location: Germany
Hello i am using 2 CC sidewinder micro for my XR10.. It s a must.. nothing else.. I get much -very much- more performece in climbing because i set the power ratio rear-front to 80:100 (or 75-100) 100% rear, 80% front.. perfect! Werner7 Sanwa MT4 two CC sidwinder XR10 3S lipo |
10-11-2011, 03:16 PM | #8 |
Rock Stacker Join Date: Sep 2011 Location: Norway
I use my dual esc`n VERY active all the time when crawling.. Setting the rear from -60% and up to 120% in some situations.. Mostly it`s set at 90-100%. (rear esc) I could never go back to a locked % distribution after seeing what variable can do.. But i`m sure its better to do 1 tooth more up front, than 50%-50% on a single esc setup.. |
