11-23-2011, 01:10 PM | #61 |
Reel nice work Mark yeah dumb pun intended.... |
11-23-2011, 02:25 PM | #62 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
2 screw mode is just the 2 screws going all the way through the housing with lock nuts, instead of just threading into the top housing... right?
11-23-2011, 02:36 PM | #63 | |
Rock Crawler Join Date: Mar 2009 Location: Irving Texas
one screw thru the bottom all the way thru the top link mount plate with the black nut shown in the pics on page one. the other is across from it in the bottom as well 4-40 with a little gold Losi SMALL nut, (this one only goes thru the two case halves, you may have to grind the plastic a little for the nut to fit.) this nut is directly behind the motor on the flat part of the top case half. it does not go all the way to the top of the case like the other one. | |
11-23-2011, 02:36 PM | #64 |
11-23-2011, 02:41 PM | #65 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
Isn't that the "you know who" mod? |
11-23-2011, 03:42 PM | #66 |
11-23-2011, 04:41 PM | #67 |
You might be the 1st to have done this mod Mr. Reel....but you DO do it the BEST! Ha! I said do do. |
11-23-2011, 05:59 PM | #68 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
11-24-2011, 11:25 AM | #69 |
Quarry Creeper Join Date: Sep 2008 Location: Rogue River
Thats a real nice one of dere dem rock hopper things |
11-24-2011, 12:07 PM | #70 |
11-24-2011, 12:35 PM | #71 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
11-24-2011, 12:45 PM | #72 |
| ok, here is the mod i was talking about, the first shows a Black bolt, This is where you drill straight through the bottom case, then get a Long screw and insert through the bottom (you dont want the nut on the bottom because it will catch on rocks ) then put a nut on top where there used to be a screw. then you drill from the bottom, using a drill that is for a 4-40 screw through the case's and put a small gold 4-40 nut on the other side it ends up between the motor and case. This takes the flex out of the case and keeps the gears Meshed..... Knock on wood going on 5 months with no issues. Last edited by mark reel; 11-24-2011 at 12:51 PM. |
11-24-2011, 07:35 PM | #73 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
can you get a pic of were the nuts were you put the 2 screws
11-24-2011, 10:21 PM | #74 |
| pic 1 shows the nut from the left screw on pic 2 i would have to take the motor out to get a pic of the other, next time i pull it apart i will for sure, but this weekend is pretty booked not sure if i can get to it right away |
11-24-2011, 10:24 PM | #75 |
ok thanks man just when were to clarify were and how far your drilling
11-24-2011, 11:25 PM | #76 |
11-25-2011, 08:10 AM | #77 |
oh ok thanks man i thought you ment for the 2 on the bottoms of the case go through to the top of the case ok thanks man |
12-05-2011, 01:02 PM | #78 |
getting some Team Brood motors 35T, cant wait to see how they work |
12-05-2011, 02:23 PM | #79 |
Eddie's motors won't let you down |
12-05-2011, 05:28 PM | #80 |
