12-21-2011, 09:26 PM | #61 |
| Re: Krawl's "SECRET AGENT"
My mistake. I thought your scale in this pic was reading 5.9 lbs but it must be 5lbs 9oz. Still... your build is inspiring to the rest of us who just can't seem to get sub 5 pound trucks to work worth a darn. |
12-21-2011, 10:27 PM | #62 | |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
| Re: Krawl's "SECRET AGENT" Quote:
you are right and I was mistaken...this scale reads different than my large scale. 5.9lbs That picture has an slw and a Dh on it. 6lbs with the Dh combo and 5lbs 11 oz with my slw setup. | |
12-21-2011, 11:06 PM | #63 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
Hello, awesome chassis design and great setup informations You wrote... FRONT: axial xr shocks preload 8mm internal limit of 3mm external limit of 10mm fully extended length. 101.9mm fully compressed length 85mm actual stoke 17.8mm rear shocks: axial xr shocks preload 10.5mm internal limit none external limit 13.1mm fully extended length 107mm fully compressed length 89.5 mm actual stroke 17.39mm ...102 and 107mm fully extended lenght. I think there will be a problem with SCX shocks. They are 91mm or 96mm (96 with longer rod end) and that's very close to your compressed lenght. So??? Greetings Frank |
12-21-2011, 11:23 PM | #64 | |
You should be able to run them with the longer ends but at an overall lower belly height. Is there a reason you want to.run those over the xr shocks? | |
12-21-2011, 11:31 PM | #65 |
Not to "post jack" what is your experience with traxxas big bores?
12-21-2011, 11:40 PM | #66 |
| Re: Krawl's "SECRET AGENT" |
12-22-2011, 01:24 AM | #67 |
| Re: Krawl's "SECRET AGENT" Simply would give them a try. I just finished a drawing for a moded SCX cap which will add the required lenght. Will keep you updated, if you like. Thanks for your quick answer. Greetings Frank Last edited by Dr.Frank; 12-22-2011 at 08:33 AM. |
12-22-2011, 08:13 AM | #68 |
12-22-2011, 09:42 AM | #69 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
12-22-2011, 10:41 AM | #70 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
| Re: Krawl's "SECRET AGENT" did you figure out a way to keep the scx shocks from leaking all over the place? if so, please share |
12-22-2011, 10:08 PM | #71 | |
I was thinking I might rebuild my shocks and pack the grease in the o rings to keep the oil in even better in my xr shocks. It should probably work very well for most other shocks too. | |
12-22-2011, 10:28 PM | #72 | |
!!NOT COOL!! | |
12-23-2011, 09:46 PM | #73 |
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
12-26-2011, 01:48 PM | #74 |
Did you try moving the rear lockout weight into the wheels yet, results?
12-26-2011, 01:52 PM | #75 |
12-26-2011, 01:59 PM | #76 | |
What's your total wheel, tire, foam, weight on the rear with weights included? Last edited by ROWDY RACING; 12-26-2011 at 02:10 PM. | |
12-26-2011, 02:17 PM | #77 |
12-26-2011, 02:31 PM | #78 |
I am at 6.7 oz with my Khaos setup, so I guess I will just add 1 oz to mine and be at 7.7 oz
12-26-2011, 02:44 PM | #79 | |
i have been doing a lot of foam testing for the last few weeks and it is truley amazing what a very well set up set of tires and foam will do to a truck. i have not changed one thing as far as "setup" during the testing. i have seen first hand how tire and foam setups are more critical to overall performance than any link/shock movement at all. there have even been a few combos that made me want to throw the truck away and start over at that point, i go back to my staring point to reasure myself that it is the combo and not me or my truck... i really think once you guys get the trucks set up your main focus will become tire and foam tuning. i have said it before, but it is the most important thing... the tires and foam are the only things that are keeping you on line and not off course. | |
12-26-2011, 02:47 PM | #80 |
Care to share your foam setup? Are you a soft or firm foam user?
Tags |
carbon fiber ftw, excellent machining, fanny packs rule!, purple baw sax, rc-trim, s.i.s.u** brood, smw, y-town crawlers |
Krawl's "SECRET AGENT" turned "DOUBLE AGENT" - Similar Threads | ||||
A Secret Agent in Boston | BC-Brian | Axial XR10 | 21 | 01-16-2013 12:10 AM |
My Secret Agent 3.5 | luxenberg | Videos! | 7 | 11-13-2012 05:42 PM |
Jakesy's Secret Agent 3.5 | jakesy | Axial XR10 | 76 | 06-16-2012 08:09 AM |
