01-26-2012, 02:53 PM | #21 | ||
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
| Re: Dr.Frank's XR Take II highflyed Quote:
Thanks Quote:
BTW, just waiting for some missing links and than you will see the final product. But if you know the name "Highfly", you should know what the chassis looks alike Greetings Frank | ||
02-29-2012, 01:17 PM | #22 |
Hello, made some progress. Cap's on (1.3mm Carbon). Traxxas BB's made it. Here are some bad pictures: Weight is RTR with 260g extra at the front axle. So now i need some time for testing Greetings Frank |
02-29-2012, 02:04 PM | #23 |
Pebble Pounder Join Date: Nov 2011 Location: Yucca Valley
Awesome stuff!!! Wish we werent thousands of miles apart!!! Then maybe id see it in person one day, pics only make me salivate uncontrolably!!! Keep up the good work
04-12-2012, 02:24 PM | #24 |
| Dr.Frank's XR Take II T1E OPS flyweigthed
Hello, i followed the YTC Secet Agent treads for a while and can't resist. Ordered a SA and picked it up yesterday. I prepared the axle during the waiting time and start to put all together yesterday. The new links i made fit quit nice, but only in the front (same dimensions as Krawl wrote in his tread) fit perfectely. The rear one need some extra love, due to the fact that i use a front axle in the rear. I also put some special work on my Traxxas Big Bores to get them at 3.5". Now i would like to let you have a little look inside the dungeon of the doctor: Max. skid clerance: Ride height: Full drop: A double FXR burger with RX sauce and CC BEC made it on the Axle: After i put all togehter i had to do a little test run in the dungeon. Now i know what Jeremy means with "suck down", man this thing is a "Sucker" (Don't get me wrong here). I just run it as it was, without any fine tuning and i'm very impressed about it. Weight is with shaved Rovers, SLW V4's, 9 oz. knuckle weights and steel hardware 4 lbs. 15 oz. Some dietary sugar is on the way, so let see where i can put it. Ah forgot, here are the measurements of the rear links: Rear lower: 150mm Rear upper: 145mm With that lenghts it sits at 318mm (That's okay for Europe). As far as i can say now, the Agent is worth every penny and minute i'm waiting for it Hopefully there some sun at the weekend... ...to be continued Greetings Frank Last edited by Dr.Frank; 09-03-2012 at 08:25 AM. |
04-12-2012, 05:03 PM | #25 |
| Re: Dr.Frank's XR Take II Secret Agent 3.5
Wow. Considering you have 9oz of knuckle weights, your truck is light! Mine is 4lbs 4oz with blitz wheels I think i need to find some fat to trim.
Last edited by EeePee; 05-06-2012 at 08:29 AM. Reason: removed quoted pics, cause it's annoying! |
04-12-2012, 05:44 PM | #26 |
Quarry Creeper Join Date: Sep 2009 Location: Detroit
| Re: Dr.Frank's XR Take II Secret Agent 3.5ed
Looks great! It looks like we have nearly identical components and mine is right around 5 lb 1 to 2.5 oz rtr with an 850 3s. I have about 80% alum fasteners but no weight savings with the FXR'S. Keep up the good work! |
04-18-2012, 04:53 AM | #27 | |
| Re: Dr.Frank's XR Take II Secret Agent 3.5ed Quote:
During the waiting time for parts i give thought to a Wraith knuckle weight system: It's inspired by YTC and would allow various weight types and positions. ...to be continued Greetings Frank | |
04-18-2012, 10:43 AM | #28 |
It would only let me press "like" once Last edited by EeePee; 05-06-2012 at 08:30 AM. |
04-18-2012, 11:10 AM | #29 |
Quarry Creeper Join Date: Apr 2009 Location: _________
| Re: Dr.Frank's XR Take II Secret Agent 3.5ed |
04-18-2012, 11:40 AM | #30 |
Quarry Creeper Join Date: Feb 2010 Location: France
looking very good Dr. !! The Sc will be rough this year |
04-25-2012, 05:05 AM | #31 |
| Re: Dr.Frank's XR Take II Secret Agent 3.5ed Thanks guys, we'll see how it performs. I put some stuff from Germany, Finnland and USofA together and did some wheelworks: ...and mounted: Not as light as YTC wheels, but with 6 braces/screws and 850 hubs not so bad The weight system is under fabrication Greetings Frank |
04-25-2012, 08:21 AM | #32 |
Newbie Join Date: May 2010 Location: Centurion, South Africa
Subscribed |
04-25-2012, 08:43 AM | #33 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Those wheels are pretty!! Nice job Frank!
04-25-2012, 05:52 PM | #34 |
For a beadlock, that's a light setup. With those wheels on, and no knuckle weights, how heavy is your truck RTR? |
04-26-2012, 01:34 AM | #35 |
RCC Addict Join Date: Oct 2008 Location: Finland
Looks good, Frank! What thickness of Carbon Fiber did you use for the Beadlock discs? I would like to try this as well. Do you have weight of the wheel without hub, tire and foam? Tomi |
04-26-2012, 02:19 AM | #36 | ||
| Re: Dr.Frank's XR Take II Secret Agent 3.5ed Thanks James. Quote:
I don't run light weight motors and only Axial LW gears in the rear... ...and only a few aluminum/Ti hardware. Quote:
Greetings Frank Last edited by Dr.Frank; 04-26-2012 at 02:21 AM. | ||
05-06-2012, 08:23 AM | #37 |
After some testing, changing, addapting it's 95% ready to rumble Balance point without wheels: Balance point with wheels: The new knuckle weights are 15mm further outside (90g each): Cut and ground VP servo armour: 0.4mm Ti battery armour: Made some spacers to preload the rear springs a bit: Front end: Back end with Egressor Ti Wraith width axles: Rubber side down: Front width sits at 275mm (10.83") with 725'er SLW hubs: Back is at 265mm (10.43") with 600'er SLW hubs: ...and here is a poser shot: I'm satisfied so far and like the way it reacts with 2080g (4lbs. 9.4oz.). As you can see, i didn't walk the super light weight way, but at this weight it's the best compromise for my driving style. Greetings Frank |
05-06-2012, 04:03 PM | #38 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
how did you do the weights with the carbon plate? are you useing stock hubs or vps?
05-06-2012, 05:38 PM | #39 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
Love what you did with the servo armor and will probably follow your way, not too light but adapted to the driver...
05-06-2012, 06:00 PM | #40 |
Super clean looking rig man. Nice work |
Dr.Frank's XR take II CK Fly V1 - Similar Threads | ||||
Dr.Frank's Mogster | Dr.Frank | Axial SCX-10 | 19 | 08-21-2011 10:54 AM |
Dr.Frank's back | Dr.Frank | RC4WD Bully | 44 | 03-30-2011 07:08 AM |
Dr.Frank's new shoes | Dr.Frank | Tires and Wheels | 13 | 10-08-2010 04:25 PM |
Dr.Frank's MRC | Dr.Frank | Losi Mini-Rock Crawler | 8 | 11-09-2009 08:24 AM |
