10-15-2012, 01:28 PM | #101 |
Quarry Creeper Join Date: Feb 2010 Location: France
| Re: Dr.Frank's XR Take II T1E OPS flyweigthed
Really great job Dr ! I can't believe how light is he .wow |
10-16-2012, 05:58 AM | #102 |
| Re: Dr.Frank's XR Take II T1E OPS flyweigthed WOW! Nice job Frank! Its amazing with the rigs being so light if that bias point changes even .125 farther back you can really feel it. Now we need video |
10-24-2012, 12:28 PM | #103 | ||||
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
| Re: Dr.Frank's XR Take II T1E OPS flyweigthed Quote:
I run a few packs through to see how the fly behaves... ...one thing is for sure, you need a very sensitive trigger finger I'm running Team Brood 16T CVR amatures in lathed GM EVO4 cans, what should i say, i love this combo a lot BTW, here's a short MT-4 lever mod instruction: Step 1: Drill three 2mm holes inside the right grip and use a sharp carpet knife to cut a small slot. Step 2: Remove the green marked screws and open to open the TX. Step 3: Use a small screw driver to loose the display cover carefully please! Step 4: Remove the trigger and the antenna plug to seperate the to housings. Step 5: Remove the trigger unit. Step 6: Widen the small slot with a key file to aprox. 2.5x10mm. Step 7: Cut of some plastic as shown in the picture. Step 8: Put the 3D Joystick potentiometer in the grip and solder the three pins to the three lever potentiometer pins (1 to 1). After soldering you can cut out the lever and remove it (or unsolder before). Step 9: Put the two housings together, rescrew them and cut a bit of the rubber grip before you put it back on. Step 10: Practice Greetiings Frank Last edited by Dr.Frank; 10-24-2012 at 10:16 PM. | ||||
10-24-2012, 01:42 PM | #104 |
RCC Addict Join Date: Jan 2005 Location: Germany north
part number of that joystick thing please |
10-24-2012, 10:08 PM | #105 |
| Re: Dr.Frank's XR Take II T1E OPS flyweigthed |
10-26-2012, 06:55 AM | #106 |
Ready to rumble: Max GC: Ride height: Min GC: Still the same weight, so now it's time for serious testing Greetings Frank |
10-26-2012, 07:13 AM | #107 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
I'm really diggin your rig Frank!! It looks great with all of your custom touches! I really like your Spring preload adjusters...very tricky |
10-26-2012, 07:23 AM | #108 |
10-26-2012, 10:10 AM | #109 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
10-30-2012, 07:49 AM | #110 |
I redo the knuckle weight holder a bit. Now there is space for 6 weights and i put 57g in each holder (a holder weights 6.5g). I placed the Tungsten weights as followed: As you can see most of the extra weight is below the axle centerline and into the front. The weights also moved to the outside: Enough space between KW and wheel: The extra weight in the front brings it to 1683g in total: ...that's 3.71 lbs.: Balance point is there where i want it to be: Greetings Frank |
10-30-2012, 10:40 AM | #111 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
simply amazing are your lower links 50/50 front to back? hope to see some footage of this truck in action soon |
10-30-2012, 12:15 PM | #112 | |
Looks awesome Frank. BTW can you just send a quick response to the last PM I sent ya... I accidentally deleted the one from you and I kinda wanted to have it Thanks! | |
10-30-2012, 12:50 PM | #113 | ||
Greeting Frank | ||
10-30-2012, 01:21 PM | #114 |
10-30-2012, 06:18 PM | #115 |
If I had 4 hands, i'd give this build 4 thumbs up |
10-30-2012, 06:48 PM | #116 |
10-30-2012, 06:52 PM | #117 |
10-30-2012, 09:59 PM | #118 |
Newbie Join Date: Jun 2011 Location: Portland
What body is that ton the first page? Interested in one.
10-30-2012, 10:52 PM | #119 |
Awsome man. I really like the body panels. Looks awsome rtr! With those narrowed pins and solid wheels it looks mean!
10-30-2012, 11:32 PM | #120 |
Dr.Frank's XR take II CK Fly V1 - Similar Threads | ||||
Dr.Frank's Mogster | Dr.Frank | Axial SCX-10 | 19 | 08-21-2011 10:54 AM |
Dr.Frank's back | Dr.Frank | RC4WD Bully | 44 | 03-30-2011 07:08 AM |
Dr.Frank's new shoes | Dr.Frank | Tires and Wheels | 13 | 10-08-2010 04:25 PM |
Dr.Frank's MRC | Dr.Frank | Losi Mini-Rock Crawler | 8 | 11-09-2009 08:24 AM |
