01-04-2012, 03:31 PM | #1 |
Rock Crawler Join Date: Sep 2011 Location: Stanford
| anyone running dual Tekin B1R's
just wondering if anyone has tried running dual b1r's on 3s lipo with 45t motors, i have 1 now, be cheaper to buy just 1 more than have to buy 2 fxr's
01-04-2012, 04:57 PM | #2 |
| Re: anyone running dual Tekin B1R's
Taken from tekin's site Controls: Forward/Brake/Reverse ON Resistance: 0.0052 Ohms Input Voltage: 4-8 Cells, 2S-3S Lipo BEC: 5.0V/1.5A Motor Limit: No limit 380 size, 55 Turn limit 540 size Reverse Type : 3 choices on board Rock Crawler Spec: 2S Lipo when used with 55T+ "540 size" motors Dimensions: 1.0 x .93 x .35" (25.4 x 23.6 x 8.3mm) Last edited by Hittman; 01-04-2012 at 05:00 PM. |
01-04-2012, 05:13 PM | #3 |
a guy called highlander in the enroute berg section shows he's running dual tekin b1r's in his berg with 2 35t motors, thats where i come across this set up
01-04-2012, 05:18 PM | #4 |
I have never had experience but i just thought i would post what tekin lists... I bet you could probably get a way with it if you were careful.
01-04-2012, 05:20 PM | #5 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
| Re: anyone running dual Tekin B1R's |
01-04-2012, 05:31 PM | #6 |
| Re: anyone running dual Tekin B1R's http://www.rccrawler.com/forum/axial...-build-up.html Second page - scroll down Been running them since I built the truck because of size and cost. I run 45T's geared 15r/16f on 3S and am fairly rough on them. After a run I can feel a little warmth on the bottom side of the skid plate from them. I tried 35T's once but felt a little more heat and no benefit so went back to 45's. I did upgrade the 100uf stock capacitors to 1600uf ones from Radio Shack. Im not easy on the throttle when Im upside down or bumping over things. The upgrade was more for personal preference from running 3S. Knock on wood but no problems as of yet. |
01-04-2012, 11:52 PM | #7 | |
| Re: anyone running dual Tekin B1R's Quote:
what is the purpose of these capacitors and what is the benefit of going to the larger size | |
01-05-2012, 05:16 AM | #8 | |
In racing it helps with run time and esc/motor temps. In crawling, and what the esc's are really ment for, its to help give the esc what we're trying to make them do while staying cooler. The B1r's arent really ment for the 3S and motors we run so if I can give the esc's a little help I figure it wont hurt. | |
01-05-2012, 07:30 AM | #9 | |
01-07-2012, 07:38 AM | #10 |
thanks for the great info guys, i'm going for it and try the b1r's
01-07-2012, 08:16 AM | #11 | |
I just went with 1600's out of habit and the ones I got were the same weight as the stock 100uf's. 1600uf@16v is all I know. Radio Shack has different ones in store but you could find a better selection through a real electronics place. | |
01-07-2012, 01:00 PM | #12 |
Newbie Join Date: May 2008 Location: excelsior springs
I think 2s with a 55 is tekins Max on a br1 but I could be wrong... Sent from my LG-P999 using Tapatalk |
01-09-2012, 11:27 PM | #13 |
Rock Crawler Join Date: May 2007 Location: Salt Lake City
How are the dual b1r's working for ya. I'm thinking about running them in my super bully with 45's on 3s too.
anyone running dual Tekin B1R's - Similar Threads | ||||
Do I still need a BEC if running Dual FXR ESC one Servo not HV w/ 3S Lipo | Strychnine | Electronics | 6 | 05-09-2014 09:29 PM |
Dual Tekin FXR thinking of running but need help please.... | vodka child | Electronics | 6 | 08-02-2011 07:20 AM |
WT Running dual MMP's on 3s 35T motors | tapped-out | Electronics | 3 | 02-19-2011 09:09 AM |
1.9 and 2.2 first build....Any other dual size running rigs out there? | lew s lugnut | General Scale Talk | 4 | 11-09-2008 05:00 AM |
