Battery tray & battery options? For the XR10, what battery tray and battery options are there? What's the biggest lipo you should use and what trays hold batteries most securely? I wanted to mount it on the front axle. (Links to buy would be a bonus) |
Re: Battery tray & battery options? Quote:
Batteries depend on motors, desired runtime, weight requirements. Go to cheep battery packs. Click on crawler packs. 800-850 for comp trucks. I run 1300 but wish I had 1000mah. Just for farting around run time. CheapBatteryPacks - cheap batteries for rc car, Lipo battery and charger, airplane battery |
Re: Battery tray & battery options? Is 'benders' a section on here? Are your lipos 2S or 3S? I guess I want good runtime on 45t motors |
Re: Battery tray & battery options? |
Re: Battery tray & battery options? I don't have the RR mount but from what I've read I think it doesn't work with the stock XR10 wheels though. Just something to bear in mind before you pull the trigger. |
Re: Battery tray & battery options? The topless mount is nice in that you can use batteries from 350mah on up to 850mah (all 3S) without rubbing the tire including the stock wheels. I have one and it works just fine with any wheel/tire I have. I mainly run in comps so I use a fresh battery per course. I guess the runtime for an 850 is about 15 to 20 minutes and the 350s are good for about 8 to 10 minutes. |
Re: Battery tray & battery options? So u can charge that in roughly 20min? Since its 3c |
Re: Battery tray & battery options? thanks for the replies :) |
