Wiring Diagram for Punk Dig and BEC 1 Attachment(s) I drew this to help me wire everything in my XR10 correctly and figured it might help others. Here's my setup, but I suppose the diagram would be fairly universal: Castle Creations 10 Amp BEC Tekin FX-R ESC Punk Dig Unit Spektrum SR300 Receiver Hitec HS-7954SH Servo at 7.4V 3S Lipo |
Re: Wiring Diagram for Punk Dig and BEC You can defiantly do it like that. First I'd wire BEC into power on the other side of the connector, so you can take the battery out of the truck, lol. You also might need to reverse a motor's wiring. I can't remember that part. Otherwise looks good. |
Re: Wiring Diagram for Punk Dig and BEC Quote:
Defiantly? What if he wanted to do it without defying anything? The word is definitely. :) That's how mine's wired. |
Re: Wiring Diagram for Punk Dig and BEC Sorry I can't spell. |
Re: Wiring Diagram for Punk Dig and BEC look's good, I wired my bec on the other side of the plug and i ran a ground from the receiver and spliced it into the ground going into the servo, I had a bit of a glitching problem and that seemed to cure it. |
Nice catch. Hopefully, I would have caught that myself. Quote:
Re: Wiring Diagram for Punk Dig and BEC Quote: i ran a ground from the receiver and spliced it into the ground going into the servo Interesting. Think it's worth doing right from the start? I don't know but couldn't hurt, the rx is made to work with all the connections so must be there for a reason I would say. I got a servo extension and took the red power wire out and wired it the way you did but I just added the ground after the male plug of the servo and it cleared the glitch up for me. I may have had a bad connection before and reworking it could have fixed it idk, lol probably just got lucky. |
Re: Wiring Diagram for Punk Dig and BEC Ok, now I'm wondering if you would even need the ground going to the BEC if you did it that way. Just have the positive lead from the BEC. Anyone? |
Re: Wiring Diagram for Punk Dig and BEC yes you still need that ground to, here is the easiest thing to get http://www.rccrawler.com/forum/vendo...s-adapter.html |
Re: Wiring Diagram for Punk Dig and BEC I edited the diagram. I like that little adapter. I was already trying to figure out how to wire the ground cleanly and this little guy looks like it should do the trick. Thanks for the help. I think I also may eliminate the ESC switch. I really want to make the electronics install as clean as I can. Don't think I want to go as far as eliminating connectors though. |
Re: Wiring Diagram for Punk Dig and BEC Hi there i have a xr10 with a fxr and a punkdig with a pl radio works great forward but when i go backward it dont go all the time.What iam i doing wrong this is all new stuff.thanks:x |
