03-02-2012, 10:13 PM | #1 |
Pebble Pounder Join Date: Sep 2011 Location: Saskatoon
| Fix your rear axle slop on the super cheap!
I see lots of people complain about the side to side slop in their rear axles with the stock lockouts. I've seen solutions recommended with shimming etc, but never seen any pictures. I was swapping in my rc4wd gears in the rear axle and figured i'd fix the slop while I was in there, so I thought I should put some pictures up so you can see. Super cheap, I just put some small o-rings over the axles that rest up against the shoulder. Slop is completely gone. |
03-02-2012, 11:20 PM | #2 |
Newbie Join Date: Jul 2009 Location: Abu Dhabi - UAE
| Re: Fix your rear axle slop on the super cheap!
an easy and cheap solution ! thanks for the picture ! |
03-02-2012, 11:23 PM | #3 |
Quarry Creeper Join Date: Sep 2011 Location: On PayPal trying to make funds appear.
i bet if the orings are tight on there they won't come off, but i would worry about it pushing in and the o ring coming around the lip. smart idea. i hope this works well, because i may do something similar.
03-02-2012, 11:25 PM | #4 |
Newbie Join Date: Feb 2012 Location: Vancouver
Trying this tomorrow.
03-02-2012, 11:41 PM | #5 |
RCC Addict Join Date: Sep 2006 Location: Depew
Awesome idea!
03-03-2012, 06:04 AM | #6 | |
| Re: Fix your rear axle slop on the super cheap! Quote:
The key is having an o-ring that fits tight enough that it has to stretch a bit over the axle. Last edited by mdchris; 03-03-2012 at 06:07 AM. | |
03-03-2012, 08:02 AM | #7 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
just put those o-rings inside the spool, it pushes on the axles so they "could" still compress, but it takes some trying.
03-03-2012, 08:57 AM | #8 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Wow...how'd you know what I was trying to fix on my bench this morning and scratching my head....gotta love this forum |
03-03-2012, 09:13 AM | #9 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
What a great idea! I have a couple of different o-ring kits with a BUNCH of different sizes, so I am doing this mod today for sure. |
03-03-2012, 10:45 AM | #10 |
The post about the O ring possible spreading and popping over the lip seems dry realistic. Best solutioN IMO is the Teflon shim traxxas makes. I think it's like $2 and you an use them all over the place. I use them to take out the side to side slip on the rear shafts, the universals on the front axle (on both the XR & AX/SCX) and a great thing they can be used for is to take the slop out of the AX/SCX top shaft. Out one steepen the shaft space Nd the slipper pin and when assembled, that notorious slop is reduced significantly. http://www3.towerhobbies.com/cgi-bin...&I=LXJJ88&P=ML Last edited by TSK; 03-03-2012 at 11:04 AM. |
03-03-2012, 11:04 AM | #11 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
+1 on what the king says. |
03-03-2012, 11:45 AM | #12 |
Yup all the other methods listed above I have seen before, and I think they would all also work just fine, but nobody has ever put up pictures of it before that I have seen so that's all I was aiming to do. Sometimes it's easier for people to see what you mean with a picture. I'm tellin you guys I tried to get the o-ring to pop over the shoulder, it's not gonna happen. You'll bend the axle first. The shoulder is taller than the o-ring on the flat sides that slip in to the spool. Whichever method anybody chooses to use they'll be happy with the results i'm sure, i'm glad to have helped some people out! Last edited by mdchris; 03-03-2012 at 11:47 AM. |
03-03-2012, 12:04 PM | #13 | ||
03-08-2012, 09:25 AM | #14 |
Rock Crawler Join Date: Jul 2007 Location: central PA
| Re: Fix your rear axle slop on the super cheap! |
03-08-2012, 10:42 AM | #15 |
Newbie Join Date: Dec 2009 Location: coquitlam
Did this mod last night to a friends worked great! now to do it to mine!
Fix your rear axle slop on the super cheap! - Similar Threads | ||||
XR10 rear axle slop | DiggyStyle | Axial XR10 | 20 | 01-16-2012 08:53 PM |
Rear axle slop... | Deezul | Axial XR10 | 26 | 12-10-2010 12:32 PM |
Cheap plastic rod end slop fix. | BENDER | General Crawlers | 13 | 11-28-2010 01:58 PM |
Rear axle shaft slop? | ittybitty | Axial XR10 | 3 | 09-12-2010 11:02 PM |
rear axle steer help(not fix, but help) | CeeBlock | Axial AX-10 Scorpion | 15 | 01-28-2008 08:06 AM |
