03-08-2012, 10:33 AM | #1 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
| Sedonas and Boss Claws
I have been running Sedonas and my son the Boss Claws. I've seen people running Sedonas on the front and BCs on the rear. Opinions on this setup? Advantages? I'll be changing over to .7" SLWs with knuckle weights, currently running around 5 lb 10 oz if that helps. |
03-08-2012, 10:54 AM | #2 |
| Re: Sedonas and Boss Claws
You'd be best served by reporting this in the "tire & wheel" section. That said it sounds like an unusual combo to me since the Sedoma will exhibit alot of tire hop when combined with high wheelspeed (due to the tall lugs) whereas the BC pin does not show this trait. Sedonas do typically show more forward bite than most tires. They are also one of the heaviest tires on the market so weight bias could play a part. |
03-08-2012, 10:57 AM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
We do it in some areas where traction is really high, making rear digs, and some ledge climbs difficult if you have too much traction. The pins help reduce rear grip with the right foam setup. I have since shyed away from this, preferring to tune foams differently and run all tires the same. |
03-08-2012, 11:03 AM | #4 |
RCC Addict Join Date: Sep 2006 Location: Depew
Each tire has a different driving style. I wouldn't think of trying to combine them in such a way. It has to make the truck unpredictable.
