Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Will these batteries work well?
Old 03-13-2012, 01:03 PM   #1
Question Will these batteries work well?
Hi,
Just sifting through my lipos... I have 4 of each of the following for my airplanes,... would either of these be good size Mah wise & physical dimension wise for a XR10 in an RR battery holder mounted on the front axle?
HobbyKing R/C Hobby Store : Rhino 1050mAh 3S 11.1v 20C Lipoly Pack
HobbyKing R/C Hobby Store : ZIPPY Flightmax 1300mAh 3S1P 20C
Mysterious is offline   Reply With Quote
Old 03-13-2012, 01:10 PM   #2
Default Re: Will these batteries work well?
not as critical if you have just the front guard batt mount, but if you have the full mount i thinks its like 20-21mm max on the width.
i run 1000mah on mine and get about 30 minutes of run time.
20c seems low. fwiw i picked up 7 1000 mah skylipo 3s (40c-80c) for about 7 bucks a piece
norcrawler is offline   Reply With Quote
Old 03-13-2012, 01:23 PM   #3
You get 30 min runtime from these?
Sky Lipo 1000mAh 11.1V 40C
FYI the hobbyking ones are 21mm width... but out of stock right now... might go w/ your skylipo
Old 03-13-2012, 01:42 PM   #4
yea, amazing batteries for the price. i wouldnt even think about running the $30+ batterys after using these.
and i thought you meant you already had the batterys in the links and you wanted to use them, if thats not the case i would go for the sky lipos.
Old 03-13-2012, 01:48 PM   #5
I have some, yes, that's correct... but I may buy a few more specifically for the XR10 at that price... at the price having a few extras won't hurt Thanks
Old 03-18-2012, 01:18 PM   #6
$7 a pack
...what a ripoff
ManxCrawler is offline   Reply With Quote
Will these batteries work well? - Similar Threads
How would these batteries work Boids RC4WD Bully 11 04-30-2010 04:47 PM
Would these batteries work for starting out? Ghostkid Electronics 31 04-10-2009 07:39 PM
which batteries will work on novak goat brushless system DAN8701 Axial AX-10 Scorpion 10 08-27-2008 06:46 PM
