03-14-2012, 08:42 AM | #1 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
| Chaotic chassis
Hey guy just bought a chaotic (XR) chassis and links super excited to get it,it can't come fast enough lol So my question is What is a good starting point in regards to- And yes gentlemen i have done a seach on this and got some of my answers just want more info What holes you useing for upper links and shock? Also what size shocks are you useing? Shock oil weight? What foams? And anything else you think i should know Any info would be great Thank you Last edited by chevotafun; 03-16-2012 at 08:36 AM. |
03-14-2012, 09:02 AM | #2 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
| Re: Chaotic chassis
Well bro...I can give you some starting points but keep in mind...everything is relative. What works on my rig may not work on yours because of differences in weight, bias terrain, drive style etc. Im currently running 4" Big Bores internally limited but 3.5" seems to be a good size for many other guys. Im running silver MRC springs in the rear and some other 1/18th scale silver spring up front. I BELIEVE they were off of a mini sprint but Im not sure. 50wt oil on all 4 corners. Shock mounts on the chassis are fronts in the last hole towards the chassis, top row and the rears are top row, 3rd spot from the chassis. Link positions are the middle hole both front and back on the VP upper link mount. Upper fronts are on the inside row, 2nd from the top with the rears on the inside row in the top spot. Like I said...my setups different from team member Paystins setup because our rigs are different. The best way to get your rig working well is bring your tools to the rock, find a semi tough line and start playing with things ONE AT A TIME. You'll need to find a happy balance. You might find that a certain link location doesn't work at all until you move your shocks. Its trial and error...test and tune. Most importantly bro...have fun. The chassis works! Good luck and hit us up if ya need any help. J.D. |
03-14-2012, 09:12 AM | #3 |
| Re: Chaotic chassis
oh i understand that just looking for a starting point to work off as i'm a noobie when it comes to building and that i've been seeing how helpfully you (chaotic Driver) have been on here so i thought i'd ask. Got a great test pile in my garage so i will be able to test the sh-t out of it to get it to my likeing.Just like i did with the stock chassis many late nights spent down there.lol We run on very slick smooth but sticky rock up here in vancouver canada my rig wieghts aroung 6.5lbs with the old chassie Are you running 4" shock all around?or 3.5 up front? or you just limiting them? Thanks JD Mike Ps- Hopefully my chassis gets here before the next comp on the 25th fingers crossed so i can show it off lol Last edited by chevotafun; 03-14-2012 at 05:27 PM. |
03-14-2012, 09:32 AM | #4 |
| Re: Chaotic chassis
If ya look in the general section you can see the test pile. Current set up Losi 4" shocks all around (do have 2 3.5" Traxxas as well if needed) White spring Have Golds as well just haven't tried them yet. 60w oil up front 50w out back HB Rovers on VP DH2 rims Proline 2 stage foam Full weight up front 3 slugs out back VP Knuckles/C-Hub VP Lock-outs VP Motor and trans plate Harden gears in the rear 45t Rockstar motors Novak M2 Dig Hi-tech 7954sh Castles Bec Coming Chaotic chassis Chaotic TI Links Ti Tie Rod VP Servo Cover Still to order VP Axail Link Mounts CI closed cell foams (front soft, rear medium) RR batt mount Was looking into getting knuckle weights but VP has been out of them forever. If there anything i'm missing please let me know Last edited by chevotafun; 03-14-2012 at 11:01 AM. |
03-14-2012, 10:24 AM | #5 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
| Re: Chaotic chassis
i run losi shocks all around 3.5 in the front 4 in in the rear 3 holes in front an rear for the tops of the shocks fronts are in the uper set of hole rears in the lower links are setup to run the closest to the center front uper are in the midle holes rears are in the upper holes losi gold springs all around with 17.5 oil tires in run sadonas up front with dubble duce foams rears are boss claws with sadona foam if your not going to run nuckle weights i ran my tire foam an rim an 12 oz rears i ran no weight at all rims were vp dirty herrys up front slws in the rear hope that helps you out an should get you a very ggod start the chaotic chasis is very easy to setup many diff ways an works well diff ways but that is where im runnin as of now |
03-14-2012, 12:35 PM | #6 |
Pebble Pounder Join Date: Jun 2011 Location: Irvine
Thankbw nnnnbnmm
03-14-2012, 01:09 PM | #7 |
| Re: Chaotic chassis |
03-14-2012, 01:10 PM | #8 |
I wanna be Dave Join Date: Oct 2007 Location: 801
| Re: Chaotic chassis
I always start any new rig with a fairly neutral setup. I will start with the upper links as parallel to the ground as possible and work from there. I have always started with my shocks laid way down in the front and stood up a little more in back. (I've done this for years so it's a comfortable place for me to start with my shocks) Then I drive it for a while and eventually start making changes. I know this is vague, but I believe it's the best place to start. |
03-14-2012, 01:19 PM | #9 |
| Re: Chaotic chassis
Thanks for your Info Chaotic every bit helps. Now if you can pull some strings and get my chassis to me ASAP so i can get started would be sweeeet lol just buggin but really i'm super stoke to get this chassis and to see what it can do.Oh and to make all the guys up here drool lol |
03-14-2012, 01:48 PM | #10 | ||
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
| Re: Chaotic chassis Quote:
Good luck man and have fun regards Dani | ||
03-14-2012, 03:08 PM | #11 | |
Pebble Pounder Join Date: Feb 2012 Location: wooster
Im still eagerly waiting, and trust me this isn't a bash, im just the kid in the candy store that can't sit still! Sorry for hijacking ...carry on Last edited by OhioCrawler; 03-14-2012 at 03:33 PM. | |
03-14-2012, 03:41 PM | #12 |
| Re: Chaotic chassis
Well i hope he can pull some strings for us but not counting on it or expecting it,but i do hope mine is being shipped with yours at least but that would still be nip and tuk for getting here for the next comp tho :( unless it gets to canada in acouple days and i spend acouple alnighters to get the chassis sorta out before next weekend.Might have to be done tho.The wifes not going to like that to much tho lol ah well got a couch down there lol And hey i'm sitting in that candy store with ya lol Last edited by chevotafun; 03-14-2012 at 03:44 PM. |
03-14-2012, 03:45 PM | #13 |
| Re: Chaotic chassis
all i can say about mark an nick is there just 2 guys an they will bust there ass to get your guys your stuff
03-14-2012, 03:51 PM | #14 | |
But till then i'm still stuck in this candy store lol Last edited by chevotafun; 03-14-2012 at 05:35 PM. | |
03-14-2012, 03:57 PM | #15 |
| Re: Chaotic chassis
lol in the candy store ya both stand up guys an will go out of there way to help |
03-14-2012, 05:48 PM | #16 |
| Re: Chaotic chassis
Any day now my friend. Just waiting on 1 last piece to be finished. |
03-14-2012, 06:03 PM | #17 |
| Re: Chaotic chassis
nice can't wait
03-14-2012, 07:05 PM | #18 |
| Re: Chaotic chassis
Im running the 4" Big Bores both front and rear and limited em to my liking. I run my front shocks pretty laid out so I can get away with longer shock. |
03-14-2012, 07:54 PM | #19 |
| Re: Chaotic chassis
what advantage or disadvantage do you find laying your shocks back compared to standing them up?
03-14-2012, 11:35 PM | #20 | |||
Chaotic chassis - Similar Threads | ||||
Chaotic crawlers Lw special chassis | ROLANDROCKSHOP | Axial XR10 | 198 | 11-19-2016 06:17 AM |
Chaotic Pro Bodiless Chassis | Chaotic Crawlers | Losi Mini-Rock Crawler | 66 | 12-24-2013 06:09 PM |
Chaotic Links on Viper Chassis? | armycrawler101st | Axial XR10 | 25 | 09-23-2011 02:46 PM |
