03-17-2012, 02:46 PM | #1 |
Pebble Pounder Join Date: Jan 2012 Location: On the rocks
| My XR10 Last edited by eulerk427; 03-19-2012 at 11:48 AM. Reason: Adding Information about the XR10 |
03-17-2012, 02:53 PM | #2 |
| Re: My XR10
This is my XR10 I just got done building. I have a Tekin FXR esc, (2) rc4wd 55t motors, Aluminum links upgrade kit, Hitec 7955 tg servo, rc4wd rockdig II, rc4wd 2.2 Outcroppers and JConcepts body. I am running a Spectrum trans and receiver. It crawls nice and has good power. Still working on tweeking this a bit.
03-17-2012, 03:02 PM | #3 |
Quarry Creeper Join Date: Feb 2012 Location: dryden
| Re: My XR10
like the colour, one suggestion tho, get yourself a set of rovers or sedonas, cheap and way better than the ones you have on imop.
03-17-2012, 07:12 PM | #4 |
| Re: My XR10
I know a lot of guys I crawl with use them. I wanted something different and these seem to work pretty well. Thanks for the advice tho.
04-29-2012, 06:36 PM | #5 |
| Re: My XR10
Adding some upgrades to my XR10. Axial heavy duty motor plates and bearings, Crawler Innovations dual foam inserts and motor covers, Axial black shock springs and CKRC front & rear axles with the brass inserts. Added Rc4wd turbo BEC. Hopefully this will keep my stock gears from breaking and give me a little more articulation and better traction on the rocks. Pictures of upgrades to follow soon. Last edited by eulerk427; 04-29-2012 at 06:44 PM. |
05-03-2012, 01:48 PM | #6 |
| Re: My XR10
Received my axial black springs today along with front and rear axles with brass incerts, heavy duty motor plates and bearings and my bullet weights fro the rims. Just waiting on my crawler innovations foams and motor covers to get here.
05-03-2012, 02:48 PM | #7 |
Rock Crawler Join Date: Jan 2011 Location: New Brunswick
| Re: My XR10
What axles are you referring too? Gotta link?
05-03-2012, 06:06 PM | #8 |
RCC Addict Join Date: Nov 2011 Location: the not so white north
| Re: My XR10
here it is. basically just the stock diffs with the brass insert mod done already. https://www.ckrccrawlers.com/ckrc-mo...2c65caf33e83b8 |
05-03-2012, 06:13 PM | #9 |
| Re: My XR10
Cool, thanks. I didn't know that they sell those already modded.
05-04-2012, 05:04 PM | #10 |
| Re: My XR10
Here is my new parts. Front tire weights and complete weight of my XR10 with stock chasis. |
05-07-2012, 02:02 PM | #11 |
| Re: My XR10
I ordered two new Tekin 45t motors from RPP and lengthened and lowered my suspension on my XR10. Hopefully with all the recent mods it will crawl better and save parts breakage. I will post pics when all back together.
05-07-2012, 04:46 PM | #12 |
Rock Crawler Join Date: Oct 2011 Location: smithville
| Re: My XR10 What length were you at originally as compared to the new longer links?
05-07-2012, 07:46 PM | #13 |
| Re: My XR10
Almost 11 & 3/4 inches, I removed all the short rod ends and replaced with longer ones. I also moved my shocks out to gain more articulation. I went from 3 1/4 inches belly clearance to 2 5/8 inches. I gave up some clearance but it crawls and sidehills better now.
05-07-2012, 08:25 PM | #14 |
| Re: My XR10
I am curious, does anyone know what laying the shocks down does?
05-08-2012, 03:55 AM | #15 |
| Re: My XR10
No, what? |
05-08-2012, 04:02 AM | #16 |
Pebble Pounder Join Date: Mar 2012 Location: Warren, Mi
| Re: My XR10
I think it changes the leverage points on the suspension.
05-08-2012, 04:40 AM | #17 |
| Re: My XR10 |
05-08-2012, 05:55 AM | #18 |
| Re: My XR10 Thank you, I could never quite figure that out,does that decrease articulation?
05-08-2012, 05:58 AM | #19 |
| Re: My XR10
I don't believe so, because the shock stroke stays the same. To limit articulation, you need to shorten the travel of the shocks.
05-10-2012, 11:59 AM | #20 |
| Re: My XR10
Here is my XR10 all back together and running great. My delrin motor covers by Crawler Innovations and Tekin 45t'S. Front springs are Axial black and Axial heavy duty motor plates and bearings. Added a fan to my Tekin FXR to help keep cool. Let me know what you think. |
My XR10 - Similar Threads | ||||
Jakesy's XR10 video thread ( latest vid-XR10 vs Bully) | jakesy | Videos! | 28 | 05-15-2011 04:49 PM |
