Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Stock chassis to Chaotic chassis...shorter wheelbase...fixed
Old 03-18-2012, 09:20 PM   #1
Default Stock chassis to Chaotic chassis...shorter wheelbase...fixed
I just changed over to a chaotic chassis and links, and now...
Full ride height its at 11-5/8"
Normal ride height its at 12".
At full squat its at 12-1/4"
Is this right? I already know without driving it there's about 2-3 lines I wont be able to make, ill just be to short to reach the lip of a ledge. Am I doing something wrong? I am using revo ends...
OhioCrawler is offline   Reply With Quote
Old 03-18-2012, 09:25 PM   #2
Default Re: Stock chassis to Chaotic chassis...shorter wheelbase...
Just back out the rod ends a couple of turns in the front and the back. That will get you to 12.5" in no time.
paystin is offline   Reply With Quote
Old 03-18-2012, 09:31 PM   #3
What is your gc? Do you possibly have any pics of your set up??? Our links are designed for a 12.5" wb. I'm guessing your suspension is not limited and your gc is so high it's bringing the axles close together.
Well get you taken care of.
Chaotic Crawlers is offline   Reply With Quote
Old 03-18-2012, 09:32 PM   #4
Simple enough. I guess I was worried and thought I better thread them all the way. Simple things like this is why I appreciate you and everyone else on here! So easy in fact I feel dumb for even asking...
Old 03-18-2012, 09:34 PM   #5
Even tho turning the rod ends out should work it shouldn't be necessary.
Old 03-18-2012, 09:35 PM   #6
Ground clearance at normal(settled) ride height is 3-9/16" at the center. Give or take a hair from the front and back of chassis
Old 03-18-2012, 09:40 PM   #7
But even at full squat, bottoming out the suspension, its only at 12-1/4"
Old 03-18-2012, 09:41 PM   #8
Could you post up some pics?
Old 03-18-2012, 09:45 PM   #9
Yes gimmie a few mins
Old 03-18-2012, 10:07 PM   #10
Old 03-18-2012, 10:16 PM   #11
ok if i remember here the stock shocks are a little long . the gc is way to tall. it should be like 3 in the front an 3 1/2 in the rear. this would make the wheel base rite . with the stock shocks you mite have to lay them down an little more . i think marc ran the stock shocks for a bit an he should be able to help here but i think thats what the prob is . the bodys on the stock shocks are to long an dont let it set down where it needs to be so you have to lay them in more to get it there
slowride1 is offline   Reply With Quote
Old 03-18-2012, 10:17 PM   #12
move the uper to the inside set of holes as well
Old 03-18-2012, 10:21 PM   #13
Ok ill jump back on it tomorrow after work. Its 12:20am and i gotta be up for work at 5:15am
thanks for the suggestions so far everyone. i know ill/we'll figure it out
Old 03-18-2012, 10:22 PM   #14
with out taking mine apart to show you i foung this an this is when i was setting up mine
Old 03-18-2012, 10:24 PM   #15
we will help you get it lined out
Old 03-18-2012, 10:25 PM   #16
i did notice something . you will want to screw the shocks into the chasis brass not like you have it in your pics
Old 03-18-2012, 10:29 PM   #17
Yeah i noticed i did that as well. thought it would be ok, but does give some flex the way i did it. ill get that corrected for sure
Old 03-18-2012, 10:36 PM   #18
by moven the uper links to the inside set of hole will let ot grow a little more as well . mine is a little short till you smash it down an then it rite at 12.5
Old 03-18-2012, 10:55 PM   #19
Moving the front uppers in one hole will give you some more caster too. You can also move the rear uppers in one hole and that should get you were need as well.
Old 03-19-2012, 05:02 AM   #20
Yeah I suppose. But I was hoping to move links to tune the suspension, not just to get a wheelbase issue fixed. I started on the outside holes to help clock the axles and give more clearance to the motors. Also, I haven't driven this yet, links and everything except the front shocks were placed at neutral center holes.
Ill work on it more when I leave work...
Stock chassis to Chaotic chassis...shorter wheelbase...fixed - Similar Threads
shorter wheelbase bahogtubig Redcat Crawlers 3 12-14-2010 06:58 PM
Aftermarket stock wheelbase chassis??? ratpower396 Tamiya Clod Buster 1 01-29-2010 09:33 AM
19.5 inch wheelbase stock chassis 56K WARNING 00TJ General Crawlers 18 08-10-2006 10:03 PM
Lengthening Wheelbase, on stock chassis Emaxx Chad G Traxxas Crawlers 11 02-25-2006 03:35 PM
