Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: Y-town Secret Agent 3.5 Bodiless XR10
Old 03-28-2012, 03:27 PM   #21
Default Re: Y-town Secret Agent 3.5 Bodiless XR10
Originally Posted by TheSCorpionKing View Post
I hope you sercure your servo better than that.
And did you sort out the link binding with the Chaotic links?
That servo will be fine. I ran a entire season just like that
Links are fine, front lowers bind a little. Like krawfreak said I need to bend them some more or add a few shims.
klabeaume is offline   Reply With Quote
Old 03-28-2012, 03:44 PM   #22
Originally Posted by Robbob View Post
If you cut that big cap off the bec it'll fit right under the servo.
Did it to mine and havent had any problems with out the cap on it.
Also with some 16/18g wire you can get those esc's even smaller and ligher if you wanted.
Trucks coming along nice
..... what hubs are you running on your front wheels?
Thanks for the tips, I am running 850 in the rear and 725 in the fronts
Old 03-28-2012, 03:59 PM   #23
TSK
Shelf queen
TSK's Avatar
If you are using Revos in the front of the lowers, they don't fit properly in the axle housing, and bind. You either need to clearance the housing a little, shave the tip of the Revo, or run the stock XR bent rod end.
TSK is offline   Reply With Quote
Old 03-28-2012, 04:02 PM   #24
krawlfreak is offline   Reply With Quote
Old 03-28-2012, 04:36 PM   #25
With shaved front lower rod ends like krawlfreak's pic and slightly twisting your links inward there will be no binding.
Chaotic Crawlers is offline   Reply With Quote
Old 03-28-2012, 07:14 PM   #26
Cool I'll give that a shot. Thanks
Old 03-28-2012, 07:36 PM   #27
TSK
Shelf queen
TSK's Avatar
Damn I'm good.
Old 03-29-2012, 03:43 PM   #28
Damn I'm good.
Thanks for your help
Old 03-31-2012, 10:48 PM   #29
Ready for tomorrows comp. I've put about 3 packs through it, tuned on the shocks some, and played around with some weight and rear link locations. I removed some hardware from the wheels and current RTR weight is 4lbs 13oz
I need to try and get the weight down some more but I really dont see how I have an extra 1lb over other secret agent rigs. I know the 7980 is temporary until I get a 7950. That will shave a few ounces. Aluminum screws will help as well.
Old 03-31-2012, 10:59 PM   #30
The wheels are a large part of the weight...
What does your wheel ,tire,foam combo weight?
Also the really light guys are running 2 or less oz per knuckle weight or none at all.
Old 03-31-2012, 11:05 PM   #31
wheel, tire, foam hub combo comes in at 5.9oz each
current knuckle weight is 2.9oz per side.
Old 03-31-2012, 11:17 PM   #32
Micro deans, lose the heat sinks and cases on the esc's, aluminum screws and ball ends, and wheels, I'm down to 4 ounces even per wheel/tire.
Almighty Malach is offline   Reply With Quote
Old 03-31-2012, 11:23 PM   #33
Yep right at 4 oz per wheel here as well.
That's 8 oz right there. Decasing and aluminum will get even closer.
Old 03-31-2012, 11:24 PM   #34
Are your wheels available yet? Or just the faces?
Old 03-31-2012, 11:31 PM   #35
The wheels are really only faces and rear rings...
You can see them in detail in my thread....you can pm me for the specifics thumbsup"
Old 04-05-2012, 12:34 PM   #36
Well, during some practice I broke a 2nd gear shaft. So, after I preached about stock gears holding up I can put my foot in my mouth and buy some axial machined gears. I may even get the rc4wd or VP cases just to have larger bearings and less flex in the axles.
Other than that I am enjoying the setup. I need to work on the front "push". and It seems to dive into holes instead of being able to float a tire like my berg. Once I get these two issues resolved I'll probably designated the xr as my new comp rig.
Old 04-10-2012, 05:02 PM   #37
Also, cut the skid down to clear the new esc mount. Rounded the edges off and added a small bend to help prevent hangups.
[/QUOTE]
How did you bend the skid like that ? some tip ?
thks,
Emmanuel.
CrawlrKing is offline   Reply With Quote
Old 04-10-2012, 05:47 PM   #38
TSK
Shelf queen
TSK's Avatar
thks,
Emmanuel.[/QUOTE]
Heat
Old 04-10-2012, 08:27 PM   #39
thks,
Emmanuel.
Heat[/QUOTE]
Yep Just used a lighter and a small vise
Y-town Secret Agent 3.5 Bodiless XR10 - Similar Threads
Featherweight Secret Agent 3.5 Bodiless Build 4xFord Axial XR10 241 06-20-2012 05:43 AM
Racers Y-Town Secret Agent 3.5 Bodieless racer_zh Videos! 17 04-12-2012 06:35 PM
Jakesy' Y town SECRET AGENT jakesy Videos! 28 03-01-2012 11:09 PM
Y-Town Secret Agent on Testdrive racer_zh Videos! 3 01-26-2012 10:14 AM
