Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: How much castor is everyone using
Old 04-03-2012, 08:05 AM   #1
Default How much castor is everyone using
How much castor are you guys running. Center, clocked all the way back in the stock slots or machining the c hubs to get one more back?
vypr is offline   Reply With Quote
Old 04-03-2012, 08:29 AM   #2
Default Re: How much castor is everyone using
machined 1 more back went two over stock but actually didnt like it.
joshsmith512 is offline   Reply With Quote
Old 04-03-2012, 08:34 AM   #3
Try to Bend it
Highlucks's Avatar
One extra slot in VP Knuckles.
Highlucks is offline   Reply With Quote
Old 04-03-2012, 08:35 AM   #4
Stock all the way back, tried the machined for extreme castor route, did not like it.
ROWDY RACING is offline   Reply With Quote
Old 04-03-2012, 08:39 AM   #5
Originally Posted by rowdy racing View Post
stock all the way back, tried the machined for extreme castor route, did not like it.
x2.
PsychoCrawler is offline   Reply With Quote
Old 04-03-2012, 08:42 AM   #6
It really depends on how you have your motor sitting. If its sitting low, one back is a lot. But if you clock motor up, you need to machine an extra slot, just to get to same as if motor sits flat.
articzap is offline   Reply With Quote
Old 04-03-2012, 08:47 AM   #7
One more than stock works well for me. I redrilled the cases instead of messing with the c's..
frdtrkguy is offline   Reply With Quote
Old 04-03-2012, 09:37 AM   #8
8* seems to work good for me.VP C's moved all the way and then the rest done with my upper links.
Der Kampfer is offline   Reply With Quote
Old 04-03-2012, 11:16 AM   #9
I don't use any castor since it's a monunsaturated oil derived from the castor bean.
But I do set the caster set all the way to the rear. (Max caster).
http://www.lorrccc.com.au/uploads/hudy_setup.pdf
AreCee is offline   Reply With Quote
Old 04-03-2012, 09:04 PM   #10
Darn iPhone kept changing the spelling LOL. I have the hudy book. It's the holy grail of rc setup LOL.
How much castor is everyone using - Similar Threads
Castor? ROCKST*R Losi Mini-Rock Crawler 3 03-21-2012 05:27 AM
Castor Briguy-01 Team Losi Comp Crawler 6 11-29-2010 11:53 AM
Integy HD Castor+Steering Block. worth the $? NSR_CIVIC Tamiya Clod Buster 3 10-15-2009 04:48 PM
Integy Castor Blocks & Clod Knuckles The BFG Tamiya Clod Buster 3 10-25-2007 03:57 PM
rear steer castor Old Way Axial AX-10 Scorpion 7 10-01-2007 01:35 PM
