04-10-2012, 08:31 PM | #1 |
Quarry Creeper Join Date: May 2011 Location: Salt Lake City
| RockDrifter's Chaotic
SO i have had this chassis for awhile now and have been really pleased with it. Purchased the CC Pro LW w/ 1/16th cab from 53willy when he switched to carbon. Rocked it for a few comps. Learned new setups and took it to UT State Champs in St George. Broke the cab in 2 spots, cooked 2 fxr's and the cc bec. Needless to say it called for some serious rebuilding. Going to school for Advanced Composites Manufacturing and Engineering has its benefits when needing to get spendy materials. Laid up 4 different carbon panels with differing layup directions and materials. The main chassis side plates are cut from 2mm 282 Prepreg Carbon. The cab is cut from 1.4mm uni directional with 282 for looks. The other plates i made for this experiment are 1.2mm Uni, laid up in a -,+,90,90 orientation. This stuff was scary thin and i thought it would hold up... but no. stress splinters after a 3ft tumble made me re think comp'ing with it. So here is a pic of my current set up. ( no Skinz ) yet. Got me a fresh set for painting. Killer clearance CC Chassis CC Ti Links Dlux wheels Ft 725 Hub @.5 width Rears 850+1/8 spacer Hub @ .7 width 7980 @7.4v XXL BigBores (mini t pinks all around) Castle Micro Sidewinders CC BEC Novak 45ts (want some brood action) 4pl R2104GF 500mah and 850's Shaved Losi Claws w/ CI DD 5" Narrow inners and Soft Outters Al Hardware where i could get it All plastic xcept VP knucks. RTR Weight w/o knuckle weights or skinz 3lbs 12 oz Bias.... wanting to go forward with this... picking up some Dlux knuckle weights tomorrow along with some carbon wheel faces... and a paper scale to get solid figures... thinking of ways to shed more... Ideas? i dont know if going to Delrin Braces will save that much but its an option. Last edited by RockDrifter; 04-10-2012 at 11:16 PM. |
04-10-2012, 08:55 PM | #2 |
Rock Crawler Join Date: Oct 2011 Location: smithville
| Re: RockDrifter's Chaotic
Hey just curious, why don't you have a rear axle brace? Also why do you have your rear wheels so narrow? Nice truck btw
04-10-2012, 08:55 PM | #3 |
Looks like the servo and the shocks are areas you could drop some weight if you wanted to.
04-10-2012, 09:00 PM | #4 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
man im jelous everyone seems to come up with these carbon chasis an i cant get one looks killer man |
04-10-2012, 09:03 PM | #5 |
I wanna be Dave Join Date: Oct 2007 Location: 801
| Re: RockDrifter's Chaotic |
04-10-2012, 09:05 PM | #6 |
im sure it will but would still like to have a carbon special for the berg build
04-10-2012, 09:05 PM | #7 | |
| Re: RockDrifter's Chaotic Quote:
I have ran the Losi BC's fat and skinny... at 1" wheels they worked very well... At the last comp i was at i got to Judge. Shamrock Showdown in St George. Almost everyone running claws out back had them pretty narrow. RCBoxer is the driver that sold me on the shaved BC's on .7's And most of the Y-Town guys too. Manu took 1st and i want to say he is skinny in the rear too. try it... you can always go back! | |
04-10-2012, 09:07 PM | #8 |
04-10-2012, 09:07 PM | #9 |
04-10-2012, 09:10 PM | #10 |
| Re: RockDrifter's Chaotic if Mark and Nick of Chaotic are going where i think they are... the wait is worth it. They have some great contributing crawlers that know whats working. Krawl put out a killer platform... and it took some time to get his next level out... and its cool as hell... Chaotic is stepping up to that. Ill be in line too Mark! |
04-10-2012, 09:30 PM | #11 |
yes im very happy with the chasis thaty i have an it works very well for me so i cant wait to see what is commin next |
04-10-2012, 09:35 PM | #12 | |
I don't blame you on the servo...I've got one on my sporty rig and it sure is fun to move rocks around | |
04-10-2012, 09:54 PM | #13 |
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
04-10-2012, 10:44 PM | #14 |
The rig is looking good...Im curious to see its total finished weight!! |
04-10-2012, 11:14 PM | #15 |
04-10-2012, 11:26 PM | #16 |
04-11-2012, 05:53 AM | #17 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
Subscribed 1. Al top links will be lighter than Ti 2. Long steel screws could be swapped & shortened for Ti to save weight 3. Get the shocks in a lathe and turn down the hexes 4. I like the super clocked rear axle, I went down that route too and mounted the rear lower links and shocks in the same place as you - so the original lower mount can be got rid of for more weight ...what weight oil and pistons are you running? Last edited by ManxCrawler; 04-11-2012 at 10:54 AM. |
04-11-2012, 03:43 PM | #18 |
| Re: RockDrifter's Chaotic 20 in the rear with a 3 hole 15 in the front with a 2 hole. The rear could be softer... but i think its a binding problem more than shocks. i know my rear uppers need to be remade.. they are just what i had for the build but the hit the top of the motor when its clocked up that high. Some things i have read through out the Light builds are the Al balls from Traxxis anyone know the part # off the top of their head? and another thing i cant seem to place is on some of the Agent builds they have a spacer under the VP top link mount... is this a home made job? or is some one selling a kit to get the final drive gear in the right spot still? |
04-11-2012, 03:54 PM | #19 |
Rock Crawler Join Date: Feb 2008 Location: Dortmund, Germany
Hello, here you are: TRA5355X Alum. Hollow Ball Set Revo BTW, very nice rig Greetings Frank |
04-11-2012, 03:56 PM | #20 |
Full Extension Normal Ride height ( Hand placed ) See its hitting the motor can, severely affecting the rear suspension action. Im gonna give the Al a go... i can grab some of that stuff from the HomeDpot and it should be soft enough for my cheapo tap n die set to thread. Also ordered up some more Al hardware from FastenersExpress should be here Monday. Dlux may be able to cut me some delrin chassis braces that will be lighter than the axial Al's. Im also debating tearing down the trans to perform the Swiss Cheesing that Krawl has done... along with others.... but is the invitation for dirt and small rocks worth the grams of weight savings? I want to be extreme n' all but i dont have the income like he does. lol |
RockDrifter's Chaotic - Similar Threads | ||||
chaotic lw xr-10 | rjsl59 | Axial XR10 | 199 | 04-09-2012 09:27 PM |
RockDrifter's BWD Mantis | RockDrifter | Axial XR10 | 14 | 08-28-2011 03:09 AM |
