04-12-2012, 10:18 AM | #1 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| A few Questions about XR10's
Ok so here are a few questions I have about XR10's ~So does anybody run their XR10's with not weights? Like running SLW's and not running knuckle weights? ~What are the best motors for them that aren't super expensive ~What ESC's would you guys recommend that aren't too expensive? (I'd like to run dual ESC's) ~What are the best shocks to use? Thanks! Last edited by EverettY; 04-12-2012 at 10:52 AM. |
04-12-2012, 10:20 AM | #2 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
| Re: Anybody run their XR10 with no weights?
i only run 4 oz a side with dlux wheels
04-12-2012, 10:21 AM | #3 |
What do the weights and the DLux wheels weigh compared to SLWs?
04-12-2012, 10:22 AM | #4 |
with a bs an sadona foam it 5.4
04-12-2012, 10:27 AM | #5 |
How heavy are the SLW with sedona's and foams?
04-12-2012, 12:42 PM | #6 |
Rock Crawler Join Date: Jul 2009 Location: Wil - Switzerland
| Re: Anybody run their XR10 with no weights? That depends what foam you are using and how the Sedonas are shaved down, mines are about 5.5 oz with Eddies new cc inner and soft outer, the sedonas are shaved. Slw's with VP 600 hub. But I'm sure there is some space to get less...
04-12-2012, 12:46 PM | #7 |
| Re: A few Questions about XR10's
ya i was thinking my slws with a dubble duce foam an bc was 6.2
04-12-2012, 12:48 PM | #8 |
i mcan get my wheels liter than what they are but i wasnt really shooting for the really lite rige it kinda just happend an im not as lite as some . im at 4.3 with fxr in case an a punk dig
04-12-2012, 01:16 PM | #9 |
So running SLW's is heavier than the DLux wheels and knuckle weights?
04-12-2012, 04:41 PM | #10 |
o hell no. the delux wheel is just a lil liter then the slw. when i was running vp wheels i run dhs up front with 2 slugs an slws out back with no weight in them . now i run the dlux whhels all around no weight in rear an 4 oz on each side with nuck weights. i think if i weigh the wheel tire an foam an nuck weight it like rite at 10 oz |
05-09-2012, 12:48 PM | #11 |
What do you guys think of running Micro Sidewinders? Have any of you ever blown any or had problems with them? Could you guys give me the Pro's and Con's of them. Also What about B1r's?
05-09-2012, 01:19 PM | #12 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Micro Sidewinders aren't bad, but I have known a lot of guys that have blown them up for a variety of reasons. If you really want a bullet proof small package, in my opinon, go with 2-Tekin FXR's, and have Chris at Creation Fab do his shrink magic. He will de-case them, solder them together and shrink wrap them. Very small package and will run 3s and big motors with no problem. Just remember to run an external BEC, like the Castle unit. Motors, I would go with Broods or Holmes Hobbies. They both offer machine wound motors that are very inexpensive and will last you a long time. I'll let the other guys answer some of the foam questions, I like a heavy rig, so I am not in on the super light trend. I just added knuckle weights and love the traction I get from lots of weight. Just what works for me is all.. |
05-09-2012, 01:59 PM | #13 |
Chris is only 2 hrs away from me. My bro also does a lot of really good soldering so he could probably do that for me . I've figured out what motor I'm going to use. I talked to Eddio and he told me what would be a good one for not to expensive. I'm going to run the Ravage 45t Matched motors. I will be running the CC 10amp BEC. And a Hitec 7950TH. Right now I'm trying to decide if I should run the new Chaotic Switch Chassis with their links or the YTC Secret Agent with CC links. The main thing that is making my decision hard is the price..... |
05-09-2012, 04:52 PM | #14 |
Dlux wheel, 850 hub (for berg with dlux axles), shavedona, CI close cell foam with soft outer |
05-10-2012, 09:13 AM | #15 |
Ahh thanks! I've decided that I will go with the Secret Agent 3.5 chassis and Chaotic Crawlers Links. One of the reasons I'm going with this over the New Chaotic Switch is because my older bro is going to build a Switch . Here is what I'm planning on starting with.... XR10 Axles YTC Secret Agent 3.5 Chassis Chaotic Crawlers Ti Links Chaotic Crawlers Ti Tierod Nordic Crawlers 2.2 CF wheels Rowdy racing front battery mount topless Custom Tires And for electronics I'm going to get... Brood 45t Ravage Matched Motors Dual Micro Sidewinders, FXRs, MMP, or Sidewinder SCT....(I'm still deciding) Hitec 7950 Turnigy Nanotech 850 3s CC 10amp BEC What do you guys think? |
05-10-2012, 10:58 AM | #16 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
i am running the vp knuckle weights with slw v4's and i also have a set of vp dh with 6 slugs in them and run no knuckle weight when i run the dh's and mine does awesome.. with the dh's with 6 slugs in each wheel im at 5.8 and with the knuckle weights and the slw v4's im at 5.2..
05-10-2012, 11:06 AM | #17 |
If you are going that far, plan on 2 sets of RC4WD gears and either the VP motor plates and gear boxes, the 9mm bushing mod to the stock plate, or some RC4WD goodies for the transmissions. Won't take long with those motors and you'll pop a set of gears. I popped my first set with stock 45t Tekins, that were used and just about worn out. Sounds like a good combo, can't wait to see the build thread. |
05-10-2012, 11:11 AM | #18 |
I'm going to be doing the mod that Mark Reel did to his axle cases to get his stock gears to last for over 5 months. I don't know if he has blown them yet....
05-10-2012, 11:24 AM | #19 | |
| Re: A few Questions about XR10's Quote:
Holmes Hobby 2012 Brushed Team Motor with checkpoint end bell. I've never run a smoother ESC than Castles Micro Pro. I like my 3.5 Big Bores with the cap mod and RPM's duel action pistons. | |
05-10-2012, 12:22 PM | #20 |
RCC Addict Join Date: Jan 2005 Location: Germany north
| Re: A few Questions about XR10's |
A few Questions about XR10's - Similar Threads | ||||
RC Adventures - 4 XR10's Comp It out | RCSPARKS | Videos! | 6 | 10-09-2010 03:43 AM |
XR10's are in!!!! | froboy | Nebraska | 25 | 10-06-2010 12:36 AM |
How did XR10's perform do at the Nationals? | Rig Rocker | Axial XR10 | 26 | 09-16-2010 11:03 PM |
