04-12-2012, 08:40 PM | #1 |
Pebble Pounder Join Date: Mar 2012 Location: Visalia
| Axle vs. Chassis for Mounting Battery - Opinions?
Mounting batteries on the front axle vs. in the chassis. Are there any gains in traction, balance, etc? What works best and why? Also, is the Rowdy axle mount the best (I know it's a "yes" but just checking)? |
04-12-2012, 08:56 PM | #2 |
RCC Addict Join Date: Sep 2006 Location: Depew
| Re: Axle vs. Chassis for Mounting Battery - Opinions?
Rowdy has the axle mount or the behind the motor mount. Both work well, but the axle one places the battery further forward. I'm so torn on what actually crawl's better. I think people are just not finding setups that actually work with less sprung mass. Although a lot of people I see finishing towards top at big events I go to, have the battery in chassis. Either way will work well, its just a matter of tuning and drive time. |
04-13-2012, 10:47 AM | #3 | |
| Re: Axle vs. Chassis for Mounting Battery - Opinions? Quote:
I just hope I can keep my hands off of that Rowdy axle mount in the mean time. | |
04-13-2012, 06:17 PM | #4 |
Rock Crawler Join Date: Oct 2011 Location: minot
try both.. i have mine sprung in a viper chassis. when the truck stretches out on a climb (proportional dig) it lowers down to JUST even with my axle end lower link mounts.. on the axle it stays in the higher position all the time, only REALLY noticeable on sidehilling or off camber climbs when it seemed like it unweighted the upper or inside front tire. |
04-13-2012, 06:43 PM | #5 |
Pebble Pounder Join Date: Aug 2010 Location: Arvada
I just moved my battery to the rowdy racing behind the motor battery mount from the chassis. I didn't notice much of a difference. I am running my xr "against the fad" right now as it weighs 6 lbs 11 ounces so my heavy weight may offset any noticeable difference.
04-13-2012, 07:00 PM | #6 | |
There's lots of info on RCC. Dig. | |
04-13-2012, 07:12 PM | #7 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
The reason I don't like the battery out on the axle is it takes such a beating. I moved mine into the chassis and switched to a smaller battery and I didn't notice any difference......Other than the battery is not out front and in the way most of the time. Try it either way and see how you like it.
04-13-2012, 07:45 PM | #8 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
Rowdy offers 4 solutions of battery mounting and I pretty think all 4 present advantages and drawbacks. The flat one over the axle, lightweight but no battery protection, the next two, better protection but somewhat bulkier that can difficult some climbing but add weight on the axle, the last behind the motor ; offering surely another biasing, protecting battery, prone to get ripped a lot and probably less easier to plug lipos... I'm just coming back from a session with my semi-protecting battery mount (axle) and must recognize it sometimes acts like a front bumper. My rig actually fell between two rocks but didn't suffer, the battery mount saving lipo and supporting the fall. It got distorted a bit but the alu conception made it easy to repair . |
04-13-2012, 08:05 PM | #9 |
Newbie Join Date: Apr 2012 Location: canada
Good thread always great to get other peoples opinions on stuff.
04-14-2012, 06:25 AM | #10 |
I used to keep the battery on the links but tried it on the axle which is where they live now. I found that the less weight on top has really helped the sidehilling and climbing being less tippy. I'm using Rowdy's topless mount and made a battery shield out of Lexan which gets strapped down on the top of the battery by the velcro strap. I'm also using the very small Hobbyking 350mah 3S packs, however, I also have 850mah packs to use if I want to add an ounce over the axle. (the same shield works with the larger pack. |
04-14-2012, 08:57 AM | #11 |
RCC Addict Join Date: Aug 2007 Location: Marshalltown
I ran mine on the Rowdy racing topless mount on my Viper chassis. When I recently changed to the T1e SS I switched to the stock location which is the chassis. I really like the feel of the chassis mounted vs the axle mounted. With the VIper it was heavier and not as smooth. Having the extra weight up front helped. Now that I run knuckle weights an a lighter rig. I prefer the weight in the chassis. Keep tuning and seeing what works for you. |
04-14-2012, 10:12 AM | #12 | |
| Re: Axle vs. Chassis for Mounting Battery - Opinions? ^^^ I agree completely... Quote:
Yeah, completely asinine! | |
04-14-2012, 11:06 AM | #13 |
Rock Crawler Join Date: Jul 2008 Location: grand rapids, bay area, nyc.
I run a low 5 lb rig and ive used both locations with no noticeable difference between the two... maybe on a 4 lb rig one might notice a difference...
04-14-2012, 06:05 PM | #14 |
I mounted mine behind the motor with electronics on the axle but didn't like it. Bias was to far back. I moved the battery back up on the axle and electronics on Rowdys motor plate. Bias was back forward and I felt the improvement on climbs. My opinion your better weight bias with it on the axle. More weight forward of the motor and on the actual axle. Sent from my HERO200 using Tapatalk |
Axle vs. Chassis for Mounting Battery - Opinions? - Similar Threads | ||||
Mounting the battery on the fron axle | downhiller6325 | Team Losi Comp Crawler | 8 | 02-24-2012 11:29 PM |
Mounting battery onto SCX10 chassis | SwampDawg | Axial SCX-10 | 3 | 03-16-2009 07:36 PM |
mounting battery to axle | speedemall | Electronics | 8 | 09-12-2008 06:35 AM |
Battery Opinions... | mschaffer66 | Electronics | 3 | 05-03-2006 08:40 PM |
Opinions on this battery pack | crawlmaxx | Electronics | 17 | 10-16-2005 06:14 PM |
