04-12-2012, 11:09 PM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
| Newbie Help XR10
Just got an xr10 roller for $100.. New.. Now im looking to get it rolling for reasonable cost.. So can get a novak Dig for decent price and was wondering what you recommend in motors? Tekin 35T or Integy of similiar turns?? And will the Novak esc run these ok.. THanks for all the help guys!! I should say this is my first crawler etc.. |
04-12-2012, 11:58 PM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: A stupid town
| Re: Newbie Help XR10
Congrats you will love the xr10 I run tekin 45t axial recommends 45t or higher motors in their book. I've never used the Novak but I'm sure it will run them no problems, integy motors are good motors if you don't want to spend a lot on your xr then I suggest you getting those just in either a 45t or 55t. Also if you plan on using the dig I recommend the spektrum dx3e it's a good radio for a low price and comes with a receiver. Good luck to you!
04-13-2012, 06:24 AM | #3 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
welcome to your new addiction! i would stay away from novak m2 dig esc... i had one,tried to make it work(@2months) and never could get it right. search the electronics section on "m2 dig " you'll see.. i would suggest a mambamax esc or an HH brxl esc and a "punk" dig control. |
04-13-2012, 07:37 PM | #4 | |
Rock Crawler Join Date: Oct 2009 Location: Michigan
| Re: Newbie Help XR10 Quote:
x2 on this. I would run 35t motors on a 3s Lipo, I ran 45's and they worked good but the punch just wasn't there. I had Tekins, and I have switched to Holmes, but for the money the Integy motors are not bad.....if your on a budget.. | |
04-13-2012, 08:30 PM | #5 |
Thanks guys!! Ok so how does this sound?? I orderd 2 novak Rockstar 45t's today! ??? And would going 2 vxl5 be a better idea for budget? I can get the Novak dig for $80.. Canadian dont forget.. Where would I order the HH or punk stuff from in Canada etc? Thanks again.. Oh and with those motors what do you recommend for lipo's? 2s or 3s? Not looking for huge punch but more runtime etc?
04-13-2012, 08:39 PM | #6 |
| Re: Newbie Help XR10 |
04-13-2012, 08:41 PM | #7 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
Spend the $20 for a star so you have access to the classified section here (and support the site!), I see Punk digs for $30-$50 all the time there. I ran Novak 45t's in mine for awhile and they worked fine.
04-13-2012, 09:26 PM | #8 |
Wow only 20mins eh?? Any way to get around an hour or at least 30ish? I will do upgrades later! But got to keep the budget wife freindly for a while..
04-13-2012, 09:57 PM | #9 |
Rock Crawler Join Date: Nov 2009 Location: poteau
go to hobbypartz.com buy 4 or 5 batteries. in a comp crawler you really want to keep weight down and smaller batteries are an easy way to do it. i run the sky lipo 800mah 3s packs and in my ax10 get around 20-25 minutes of run time per pack. okjeepin runs the same batts in his xr and gets around the same runtimes. at $6 apiece for batteries it won't break the bank!
04-13-2012, 11:05 PM | #10 |
Alright thanks for that guys.. Ive dealt with hobbyparts before and there excellent! etc..
04-14-2012, 12:04 AM | #11 |
Rock Stacker Join Date: Mar 2009 Location: canada
| Re: Newbie Help XR10 Maybe, but it seems to me alot of guys from the US are only interested in shipping to the US.
04-14-2012, 01:07 AM | #12 |
Ok so I think im in the game?? Holmes Hobbies BR-XL RC4WD rockerdig 2. And my current 3ch rx/tx with the Novak 45t motors and a good servo! Some 850-1000mah 2s or 3s servos and I should be good right??? Probably order the rc4wd gear sets while im at it etc?? Thanks for the help!!
04-14-2012, 06:02 AM | #13 |
800 mah batteries fit real nice in the XR10, larger packs like 1100-1200 are a tight fit. I'm using Hobbyking 350mah 3S 100+C for comps and they are the ticket, about 8 to 10 minutes with a low profile that doesn't rub the tire at full lock. The 850mah 3S fits but with wheel rub at full lock, however, you get about 20 minutes out of it. I'm using 2 HH 35T motors with dual FXRs and CC BEC @ 7.2V on a BJ4 chassis. The battery mount is a Rowdy topless. |
04-14-2012, 08:19 AM | #14 |
Rock Crawler Join Date: Oct 2011 Location: smithville
I use a 1300mah 3s skylipo in the chassis. It is a little tight but fits, i get around 30-35 mins.
04-14-2012, 11:30 PM | #15 |
Rock Stacker Join Date: Jan 2012 Location: On the ledge. Look up.
I run MaxAmps.com 3S LiFe packs (1050 mah) and get 65-75 min run time with 55T motors. No idea of run time on 35-45T motors. They handle 3x the number of charge cycles as a LiPo (1,000 cycles), will not catch fire, will charge at 15C, don't require low voltage cutoff, and can kick out some serious current if you want it. And it tucks into the chassis just fine. I keep mine up front between the front upper links. I've been using a Punk Dig 3D since the XR came out and the dig unit hasn't given me a single problem. It's a tank. I'm not sure what else has come out in the past year or two, but were I in need of another dig, I'd go right back to a Punk. Last edited by Vertigo; 04-14-2012 at 11:35 PM. |
Newbie Help XR10 - Similar Threads | ||||
Newbie Maxmus's Ultra Budget XR10 | maxmus | Axial XR10 | 6 | 06-07-2011 02:46 AM |
Jakesy's XR10 video thread ( latest vid-XR10 vs Bully) | jakesy | Videos! | 28 | 05-15-2011 04:49 PM |
newbie looking to make a 4 wheel steer xr10 | jari | Axial XR10 | 8 | 04-29-2011 11:18 AM |
XR10 newbie question | Randy_4life | Axial XR10 | 11 | 03-28-2011 08:55 PM |
