04-16-2012, 10:39 AM | #1 |
I wanna be Dave Join Date: Dec 2008 Location: ?
| Rear Axle Pop
So I have had two XR10 and both have had this issue with the gears not engaging and popping in the rear. Both have had light weight Axial gears. I have seen some people doing a shim or some using CA glue? What have people found to fix are rear axle issue? Thanks |
04-16-2012, 10:49 AM | #2 |
RCC Addict Join Date: Jan 2010 Location: Lafayette
| Re: Rear Axle Pop
I added some ca glue to the lower half of the housing where the spool's bearing race sits. While it was wet, I added a strip of paper to soak ip the ca and give it a more uniform height. The popping went away, but it should be mentioned that I swapped to a new set of rc4wd gears(the old rc4wd gears were a bit knife edged after over a year of use), and swapped in a new housing at the same time. Did your rear gears start popping immediately after you installed them? Mine were fine until I had about 11 months of use on them. Then the pop came. No teeth were chipped, but I think the knife edge effect on an old gear might transfer more force radially than the angles of a new gear set. KInda push the gears apart more than an old housing can handle. Last edited by shelljeep; 04-16-2012 at 10:49 AM. Reason: Spelling |
04-16-2012, 11:05 AM | #3 |
Rock Crawler Join Date: Oct 2010 Location: Switzerland
| Re: Rear Axle Pop
I do it this way: I shave alittle bit of the lower Axle half ( top side). so you can tighten the screw more and there is no more play. Its easier than glue in some paper |
04-16-2012, 11:07 AM | #4 | |
| Re: Rear Axle Pop Quote:
Thanks maybe the ca and paper is the ticket. Leave the paper in right? | |
04-16-2012, 12:00 PM | #5 |
| Re: Rear Axle Pop
Yeah, it sponges the glue and hardens up. I've read that there is enough variation in the housings that some need shimming like this but some don't. Either way, I can see how use woul flex it enough to loosen tolerances. |
04-16-2012, 12:09 PM | #6 |
| Re: Rear Axle Pop Problem I see is as that bearing spins would you think the CA and harden paper would start to break down. Maybe get the gears messy?
04-16-2012, 12:13 PM | #7 |
| Re: Rear Axle Pop I do both, although I just do a bead of ca, spread it evenly with a toothpick and let it dry. No pops out of my gears with 30t Team Broods. |
04-16-2012, 12:14 PM | #8 |
| Re: Rear Axle Pop |
04-16-2012, 12:17 PM | #9 |
| Re: Rear Axle Pop |
04-16-2012, 12:18 PM | #10 |
Pebble Pounder Join Date: Jul 2008 Location: ov, sacramento
| Re: Rear Axle Pop
personally i wouldnt even mess with ca glue in there. i just used aluminum foil and its been doing great. mine took about 6 pieces. you can dial it in perfect by throwing a few pieces in there and screwing the axle together. make sure the upper link mount is off. and you can take a small piece of aluminum foil and slide it in where the upper part of the spool bearing meets the upper seating surface of the axle. if there is slack in it just simply add more foil. add more and do trail and error until you have it perfect. everyone says they just throw a fat layer of ca glue on it. i think thats a stupid idea,it could either be to much or not enough. theres no way of getting it 100% perfect where it needs to be unless you do it this way. ive been running mine for probably 60 packs and have never had a problem. with 45t broods and 3 cell |
04-16-2012, 12:19 PM | #11 | |
04-16-2012, 12:32 PM | #12 |
| Re: Rear Axle Pop
negative. i guess what ever works gets the job done. mine has been holding up great though on a side note, i think this should be stickied. there are alot of threads on this! |
04-16-2012, 12:45 PM | #13 | |
Thanks for every ones feedback on this issue. | |
04-16-2012, 12:47 PM | #14 |
Pebble Pounder Join Date: Mar 2012 Location: Visalia
| Re: Rear Axle Pop
CA will work but it's somewhat crude. Your best bet is to get some brass or stainless steel shim stock (about .005 or .010) and cut some shims. This will ensure that the bearings are evenly spaced upward and the gears are meshing correctly. You'll have to start thin and work your way up until the gears feel too tight, then back off.
04-16-2012, 12:59 PM | #15 |
| Re: Rear Axle Pop
Look for Mark Reel's build. Had had a simple solution that should be the most secure way to remedy this problem assuming you have a plastic rear axle Housing **EDIT** Found it for you because I'm such a swell guy. Mark Reel's XR10 Build 11th place at nats Last edited by TSK; 04-16-2012 at 01:06 PM. |
04-16-2012, 02:41 PM | #16 | |
Look like one screw all the way threw tightens the axle case? | |
04-16-2012, 02:51 PM | #17 |
| Re: Rear Axle Pop |
04-16-2012, 03:09 PM | #18 |
| Re: Rear Axle Pop
2. One on each side of the spool gear.
04-16-2012, 03:18 PM | #19 | |
Quarry Creeper Join Date: Dec 2010 Location: Phelan California
Sent from my LG-P509 using Tapatalk 2 | |
04-16-2012, 06:44 PM | #20 |
| Re: Rear Axle Pop
Yep, the two screw mod is the way to go. The one that goes all the way through the three pieces should be a running change to the kit. Way too easy, and obvious.
Rear Axle Pop - Similar Threads | ||||
RC Axle Master Axial AX10/SCX10 Rear Straight Axle Kits | LetsHandleit | Axles, Trannys, T-case | 41 | 06-24-2012 06:57 PM |
rear straight axle lock out's for tamiya tundra highlift axle | tundrafan01 | General Scale Talk | 9 | 05-19-2011 01:30 AM |
Rear steer lockout so you can still mount stuff on rear axle | bill400ex | Duratrax Cliff Climber | 9 | 02-16-2010 07:49 PM |
