04-17-2012, 10:56 AM | #1 |
Quarry Creeper Join Date: Feb 2011 Location: Lynnwood
| VP Aluminum Axle Top and upper link mount
Just got my order and was wondering if the little piece that goes in the upper link mount needs to be removed? I am assuming that the bearing that is provided with the axle topper replaces this bearing. I did do a search but could not find any info on this! Thanks for the help! |
04-17-2012, 10:59 AM | #2 |
Quarry Creeper Join Date: Oct 2009 Location: Newton
That is correct. Remove the spacer.
04-17-2012, 10:59 AM | #3 |
| Re: VP Aluminum Axle Top and upper link mount
The VP upper housing allows the use of a big bearing. So the little reducer piece in the upper link mount needs to be removed. If yours is stuck (which it shouldn't be) try sticking it in the freezer.
04-17-2012, 02:13 PM | #4 |
Cool! Thanks for the replies!
VP Aluminum Axle Top and upper link mount - Similar Threads | ||||
Vanquish Upper Axle/Link Mount | meffie | Axial XR10 | 13 | 10-02-2011 08:27 AM |
Aluminum Adjustable Upper link mount | Del Monte | Team Losi Comp Crawler | 17 | 10-25-2010 01:14 PM |
aluminum upper link mount | dranger962000 | Axial AX-10 Scorpion | 6 | 01-04-2010 02:45 AM |
TCS Aluminum Boomerang Upper Link Mount for Axial AX-10 Scorpion | Larrythegreat23 | Axial AX-10 Scorpion | 3 | 03-30-2008 07:23 PM |
TXT upper link mount on axle housing?? | redrover | Tamiya Txt-1 and Juggernaut | 8 | 12-15-2006 09:26 PM |
