04-16-2012, 10:28 PM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
| Average upgrades?
I know its a weird question. But If I take a stock xr10 and put rc4wd gear sets, Vanquish Gear cases and motor plates of whatever brand? With 45t motors running 3s and maybe some link upgrades?? How durable would this setup be?? electronics I will upgrade with $ etc.. Thanks for the help guys! Im assuming that the stock gears wont last very long? From what ive been reading?
04-16-2012, 10:59 PM | #2 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
| Re: Average upgrades?
do the traxxas bushings an you will be money with the other stuff you said
04-17-2012, 07:14 AM | #3 |
Rock Crawler Join Date: Oct 2010 Location: Ontario
I drilled the plates and upgraded to 9mm bearings, bushings in the cases and link mounts with RC4WD gears. Running 35t HH on 3s no issues.
04-17-2012, 03:09 PM | #4 |
| Re: Average upgrades? |
04-17-2012, 03:53 PM | #5 |
04-17-2012, 04:23 PM | #6 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
get rid of the little bearing in the upper link mount trust me iv blown that out so many times get the bushing
04-17-2012, 07:57 PM | #7 |
Quarry Creeper Join Date: Jan 2012 Location: Okanagan Falls B.C.
Part # TRX3775 |
04-17-2012, 08:10 PM | #8 |
RCC Addict Join Date: Aug 2009 Location: Earth?
I would suggest the VP bronze bushings and RC4WD gears. If you use the VP bushings you wount have to drill or replace the motor plates. A lot of people have good luck with the Traxxas cast bushings, but I have split and broken so many its VP for me, and if you use the Traxxas bushings you will still need to do the 9mm bearing mod or replace the motor plates.. That will get you where you need to be untill you can do more later.
04-17-2012, 08:40 PM | #9 |
If you have some mechanical ability, then do the 9mm bearing mod in the stock motor plates, the traxxas bushings everywhere else in the gear cases, the "mark reel" 2 extra bolt mod in the rear housing, you'll have a pretty durable setup. Stock gears and all. You may still break the 12 tooth gear shaft if you have no throttle control (full throttle when bound up). If you'd rather just throw money at it, get VP or RC4wd motor plates, either the RC4wd or Axial machined gears, and the traxxas bushings. IMO, there's no need for the aluminum gear cases at all. 100% pure bling. |
04-17-2012, 10:40 PM | #10 |
Great stuff guys thanks for all the help!! Sounds like the bushing are the way to go for $ sake!! WIll definately look into it etc! Appreciate all the help!
04-17-2012, 11:00 PM | #11 |
Can anyone give me a part # for Decent 9mm bearings?? Oh and what size drill bit you all using?? Thanks again!!
04-18-2012, 05:02 AM | #12 |
Avid rc for the bearings, for the drill bit i went to a local hardware store (brafasco up here). 5x9x3 Flanged Rubber Bearing MF95-2RS |
04-18-2012, 05:10 PM | #13 |
Rock Crawler Join Date: Oct 2011 Location: smithville
I just bought the same ones for my xr. 9mm bit btw
04-18-2012, 10:10 PM | #14 |
Hey guys! another dumb question!! Will the Spectrum DX3C work well with this rig?? Its gonna have an M2 dig with external bec!! Iknow iknow get better esc.. This is it for now!! Im wondering for sure? If the dx3c can be setup for front/rear dig and propo dig?? Thanks for the help!!
Average upgrades? - Similar Threads | ||||
not your average 1.9s | kaneohecrawler | Tires and Wheels | 61 | 09-18-2011 07:39 PM |
NOT YOUR AVERAGE 1.9s tAkE 2 | kaneohecrawler | Tires and Wheels | 6 | 07-20-2011 10:10 AM |
not your average nylint | Bronco | General Crawlers | 12 | 04-05-2007 03:33 PM |
