04-21-2012, 11:44 AM | #1 |
Newbie Join Date: Apr 2012 Location: Naples
| Bullet Proof Build
Being new to crawling and willing to spend some money to get set up right, is there a thread that I can't find or a list to set up a low failure rate rig with quality parts? I don't think I need be set up for comp, but if that's where I end up then so be it. I've looked at Harley's thread and got some ideas, but there are lots of variables and maybe it comes down to experience and preference. Thanks for the help.
04-21-2012, 11:56 AM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Martinique
| Re: Bullet Proof Build
Hi, the weak point on the XR is usually the gears and axle flexing ! motor plate drilling or replacing for bearing mod, rc4wd gears, transmission cases if you can, chubs & lockouts to make axles solid, knuckles (VP) to go zero ackermann, BWD brace to make rear axle beefy and the thing should already be pretty strong... Some guys here recommend to take links mounts also. One more thing, change upper links for axial 30° bent ones . But if you don't use strong motors and adapt your driving, stock kit should be fine... |
04-21-2012, 12:10 PM | #3 |
Rock Crawler Join Date: Oct 2011 Location: smithville
I don't think you need all that to have a sturdy rig. All you really need is a bushing in the upper link mount. 9mm bearings instead of the 8mm's and maybe vp cases. Other than that I think you will be fine.
04-21-2012, 12:11 PM | #4 |
This -> Bender's XR10 |
04-21-2012, 12:21 PM | #5 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
if you do the vp motor plate and tranny case do you still have to do the 9mm bearing mod
04-21-2012, 12:23 PM | #6 |
No vp gives you 10mm size bearings with the plate
04-21-2012, 12:29 PM | #7 |
I think the best thing that I could do honestly would be to buy one already built and get familiar with it, but what fun is that Besides, being new to the forum, I'll have to wait for a few more post's until I can see the classified section to see if there's anything like what I want for sale.
04-21-2012, 12:34 PM | #8 |
Newbie Join Date: Mar 2012 Location: Rocklin
or just pay 20 bucks for a year and you can see them.
04-21-2012, 05:26 PM | #9 |
RCC Addict Join Date: Jul 2009 Location: Shreveport, LA
| Re: Bullet Proof Build |
04-21-2012, 06:41 PM | #10 |
That's pretty much what I was looking for! Is there also an aftermarket aluminium or metal axle tube rather than plastic? Might not even be necessary.
04-21-2012, 06:50 PM | #11 |
Check vanquish for Metal axle tops, although many deem them unnecessary
04-22-2012, 12:31 PM | #12 |
04-22-2012, 01:00 PM | #13 |
| Re: Bullet Proof Build go to the top of the page you will see user cp click on it scroll down the page on your far left you will see at the bottom in the box it will say paid subsciption then click on it and go in there and pay using paypal... it took me a little while to figure it out too....hope this helps powerhound.. |
04-22-2012, 01:21 PM | #14 |
Thanks, that's what I was looking for.
Bullet Proof Build - Similar Threads | ||||
Bullet proof shafty axles? | Dabandit1 | General Crawlers | 3 | 06-15-2010 06:15 AM |
I want to build bullet proof TLT axles | Hardrockguitar1 | Tamiya TLT Crawlers | 19 | 11-12-2006 05:03 PM |
