04-27-2012, 11:49 AM | #1 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
| servo issue
i went and tried out my new xr10 today and i got to say i really like it better than any rig i have driven but to the issue the servo is getting extremely hot and it stopped steering just like the servo was unpluged it wasnt responding in any way you could turn the steering knob on the radio either way and it wouldnt turn but a few seconds later it would turn then start working again for a sec but it was still extremely hot. did it just burn up or is there a issue with the radio.
04-27-2012, 12:17 PM | #2 |
Pebble Pounder Join Date: Jul 2008 Location: ov, sacramento
| Re: servo issue
check your end points. are you running a bec? my 7950 gets hot. if you can hold your finger on it for 5 or more seconds id say your good. ive burned up a 7950 before and couldnt keep my finger on it for a couple seconds. |
04-27-2012, 12:24 PM | #3 |
| Re: servo issue
yes i am running a bec the last time it stopped working its stopped it wont work at all now just wondering if it burnt up
04-27-2012, 12:28 PM | #4 |
| Re: servo issue
the servo is ticking just sitting here it will not steer at all
04-27-2012, 01:24 PM | #5 |
| Re: servo issue
When you turn the wheel via the tx, can you hear it servo motor spinning? if so, the gears are toast. Although Ti geared, there is still a plastic gear in there. Also, running hot either means your end points are too wide (causing the servo to try turning farther than the physical limits of the steering system, or there is major binding in the steering linkage. When the epas are set properly, the servo should make no noice when at full lock. If it is humming or buzzing, then the epa needs to be turned down. |
04-27-2012, 01:49 PM | #6 |
| Re: servo issue
You can hear nothing when turning it has a ticking noise just setting there. And I had a small cheap servo from a spectrum radio hooked it up and it works perfect so it's toast I guess. It did have a buzzing noise before though which my ax10 has the same servo and it buzzes. How do I stop the buzzing noise ? I'm gonna take the 7954 off my ax10 and put it on this rig
04-27-2012, 02:24 PM | #7 |
Pebble Pounder Join Date: Mar 2011 Location: Calgary, Alberta
Another possibility it that you were running to long of servo horn for the strength of you servo. Also if one of your front wheels in a bind if you try turning your wheels the opposite direction that will get your servo really hot really fast.
04-27-2012, 02:39 PM | #8 |
| Re: servo issue It's the new axial servo horn it's the short one
04-27-2012, 02:39 PM | #9 |
| Re: servo issue
You need to turn down your radio's End Popint Adjustments (EPA's). Adjust them so that your steering gets macimum travel in each direction, but without the servo humming or buzzing when at max lock. And adjust it while the front end is off the ground.
04-27-2012, 02:53 PM | #10 |
| Re: servo issue
It buzzes all the time not just at full lock it does it all the time so I'm not sure how it does at full lock
04-27-2012, 02:55 PM | #11 | |
| Re: servo issue Quote:
Digital servos always humm/buzz/tick at center ....... they are always trying to find center. Nothing new or harmful. Its the humm/buzz when at full lock like SK said that you need to listen for and adjust out. | |
04-27-2012, 03:41 PM | #12 |
| Re: servo issue Ok cool I'll listen for that when I get another back on here
04-27-2012, 09:46 PM | #13 |
Quarry Creeper Join Date: Feb 2011 Location: A stupid town
| Re: servo issue
Does it have the vp wraith steering end? That helps also I had the same problem
04-27-2012, 09:55 PM | #14 |
| Re: servo issue
nope it has nothing upgraded other than the chassis but i have all the xr10 vp goodies on order.
04-28-2012, 05:15 AM | #15 |
Rock Stacker Join Date: Mar 2012 Location: U.K.
| Re: servo issue The vp goodies should help because in your build thread you said it had stock knuckles and i assume stock steering arm which is too short and stresses the servo and vp knuckles have a longer one, so probably this and the epa's helped to kill your servo.
04-28-2012, 07:20 AM | #16 |
| Re: servo issue Ok thanks man this sounds good
servo issue - Similar Threads | ||||
AX 10 Servo Issue | cmlooner33 | Electronics | 3 | 03-07-2012 06:41 PM |
jr servo issue | jscalecrawler | Electronics | 3 | 12-19-2011 01:59 PM |
Servo issue | ChiefWigman | Losi Micro-Rock Crawler | 2 | 06-18-2011 10:31 PM |
Servo issue, help please! | Drvnbeing | Electronics | 0 | 03-27-2010 09:31 AM |
servo issue | chuck-biscuits | Electronics | 2 | 03-08-2005 06:45 AM |
