Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial XR10
Thread: RC4WD Hardened Steel gear set UnObtainium???
Old 04-28-2012, 02:40 PM   #1
Default RC4WD Hardened Steel gear set UnObtainium???
Hi everyone, Does anyone know who else sells the Hardened steel replacement gear sets from RC4WD for the XR10? They are still making them, right?? I have checked RPP, CKRC and RC4WD and they all say "out of stock". Please tell me that Axial didn't make them quit producing the set, did they? Any ideas on who has some in stock still? I need 2 to 4 sets (at least two of them anyway).
DiggyStyle is offline   Reply With Quote
Old 04-28-2012, 03:06 PM   #2
Default Re: RC4WD Hardened Steel gear set UnObtainium???
As far as I know, rc4wd is still making them. Just a pain in the neck having to wait forever. Have you tried contating rc4wd directly?
Good Luck
scrounge is offline   Reply With Quote
Old 04-28-2012, 04:01 PM   #3
I did a search recently (last week???) for these, the only place that had them in stock was in Canada.
I bought a different set from Tower Hobbies for a short term fix.
Since I've had issues, I would recommend to "Stay Away" from the H-R gears. We had issues, they have not replied to a few emails for help.
Charlie-III is offline   Reply With Quote
Old 04-28-2012, 05:11 PM   #4
TSK
Shelf queen
TSK's Avatar
Those gears just sell out fast. Last time I bought 2 sets when they showed in stock and they were sold out again a day later. You just need to keep checking, or source another option.
TSK is offline   Reply With Quote
Old 04-28-2012, 06:23 PM   #5
Well i just got mine in the mail today from ckrccrawlers.com awesome selection of parts and spare parts for the xr ten.
Waitin4Dv@Yahoo.com is offline   Reply With Quote
Old 04-28-2012, 07:01 PM   #6
JPcustom rc says they have them in stock! And there shipping is less than RC4wd.. Mine are on the way!
gtxr is offline   Reply With Quote
Old 04-28-2012, 07:53 PM   #7
losiking1's Avatar
Try horizon hobby. Just checked their sight and showing in stock
losiking1 is offline   Reply With Quote
Old 04-28-2012, 11:45 PM   #8
Damn I looked everywhere.. Didn't think of JP customs....
crash is offline   Reply With Quote
Old 04-29-2012, 06:29 AM   #9
Thanks so much for all the info guys! I'll start working those resources til I get my hands on some! I appreciate it!
Old 04-29-2012, 07:33 AM   #10
"Mad rush to buy up gearsets....."
I did a PN search through Google, all hits came up "out of stock" except for one place in Canada.
Link to Horizon Hobby page.... Hardened Steel Replacement Gear: XR10 | Horizon Hobby ....in stock....
JP Customs page.... RC4WD Hardened Steel Replacement Gear Set for XR10 ..... Out of stock.
Old 04-29-2012, 09:07 AM   #11
Use the notify by email option if the site has one.
SINister is offline   Reply With Quote
Old 05-03-2012, 07:09 AM   #12
Charlie, What was the issue that you had with the HR gears? My brother just got a set of them and he was having some problems too right off the bat. Did you get them direct from the company or from CKRC (which is where he got them)? Who did you email? Sorry for all the questions, just trying to set up a plan of action that my bro will no doubt have to be taking soon with his HR gear problem.
Old 05-03-2012, 08:55 AM   #13
I have a few posts in this section regarding it....actually I believe a thread.
Bought from an online shop in New England. There are 2 shafts with a 12T (?) gear cut into the shaft and a 36T (?) gear pressed onto the shaft (stock parts have the larger gear pinned on......my son broke the shaft where the pin hole is).
For both shafts, the larger gear spun on the shaft.
Shaft is really too hard to drill.
Welding it on will likely either warp the gear or remove the hardness.
I did a temp fix, but it only lasts a pack or 2.
My thread.... Hot Racing hardened gear set issues...
Old 05-03-2012, 09:47 AM   #14
Dang--got an email from JP--- "we are sorry but the site was broken and the stock on hand was wrong"---looks like a couple weeks again waiting...
Old 05-03-2012, 10:56 AM   #15
I'd wait for the RC4WD ones. They are worth it. Aside from having to grind the screw that holds the 4 link plate on to clear the gear they are awesome. I just tore my axles down the other day to instal my VP axle tops and they gears are in perfect shape after 2 seasons of crawling. re-greased and reassembled. no changes
ev0l is offline   Reply With Quote
Old 05-03-2012, 11:10 AM   #16
ax10tn's Avatar
im waiting on a set from rc4wd im on the waiting list i have all vp stuff on my xr10 except for the axle tops will i have to grind down the screw on mine with the vp motor plates,4 link mounts and housings? which screw do you have to grind?
ax10tn is offline   Reply With Quote
Old 05-03-2012, 12:31 PM   #17
The CKRC gears are the Hot Racing gears.
It has been my experiance that JPCustoms site says in stock when it is not.
I have used all the gears made except the new Hot Racing light weight gear set, and it dosent come with the final drive gear. So for the price and no final gear I wont be trying them.
Stock: The 12T Transfer, 22T Drive, and 36T Final gears must be replaced at a minimum. The rest are fine.
Hot Racing: I only used the HR gears to replace the above gears. The 12T worked fine. I broke teeth off the 22T, broke teeth off 1 final, cracked the center of another where the axle goes in, and had another that was cut off center and wobbled.
Axial Machined: Awesome if you can deal with the popping, or can shim it out. Only really need the 12T transfer, 22T, and 36T final.
RC4WD: Were out fast, and sloppy mesh. I have folded over the teeth on the 22T and 36T final on 2 sets due to were.
KBrog is offline   Reply With Quote
Old 05-03-2012, 03:52 PM   #18
i just ordered them from rc4wd... twice in the past month, shipped relatively quickly..
T3rry is offline   Reply With Quote
Old 05-03-2012, 04:00 PM   #19
ax10tn's Avatar
so i need to order a final drive gear along with the rc4wd gear set?
Old 05-03-2012, 07:11 PM   #20
Yikes! I am not going to buy any gear sets except RC4WD or Axial hardened (although at half the price, the RC4WD get's my vote ) I will stay clear of the HR stuff. As for an update: My bro contacted CKRC and spoke directly with someone there. They are going to fully refund his money, (they offered to send him new sets but he declined). He's already on the waiting list for some RC4WD gear sets. I am too.
RC4WD Hardened Steel gear set UnObtainium??? - Similar Threads
Robinson Racing Products One Piece Hardened Steel Outdrive/Diff Locker Gear bunson70 Axial AX-10 Scorpion 27 09-27-2012 02:45 AM
