tire rub on springs who runs internal spring shocks. |
Re: tire rub on springs |
Re: tire rub on springs im running shocks with the mini t springs with 1' wide vp wheels with 350 hubs and mine just barley touch the shock body at full lock. |
How far back is your castor? I currently have mine set 1 step further back than max with unmodded c's and I can't steer sharp enough to even touch the shocks. At max stock castor they would just slightly rub to where it isn't enough to worry about Sent from my iPad using Tapatalk |
Re: tire rub on springs I'm running full stock set up with no caster adjustments. to get any kind of turning radius the tires rub on the shock springs. |
Re: tire rub on springs I run my big bores upside down in the front. Let em rub...the springs are out of harms way. |
Re: tire rub on springs I sort of like the way the springs spin when the tires rub them. |
Re: tire rub on springs Quote:
Sent from my PC36100 using Tapatalk 2 |
