05-01-2012, 02:16 PM | #1 |
Pebble Pounder Join Date: Mar 2012 Location: Visalia
| Battery tray - adjustable easy access concept
An idea I'm kicking around to replace the silly stock tray. The new concept battery tray is red and could be made from 1" x 1" x .062" aluminum angle. Your thoughts? Three lower holes to give it an adjustable angle (10, 20, or 50 degrees) It is shown at 50 degrees but could go almost flat. |
05-01-2012, 02:25 PM | #2 |
| Re: Battery tray - adjustable easy access concept
Somebody had some free tie on their hand. I used a BWD tray when I ran the stock skid. And now I just drop the whole skid out on my SA if I need access to the guys. Seems a bit overkill to me since i don't have to get in there too frequently. |
05-01-2012, 02:50 PM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
Not a bad idea I think but you need to drop it much lower - basically riding on the lower links - to get the CoG as low as possible. I'm happy with my RR axle mounted tray FWIW. |
05-01-2012, 03:09 PM | #4 |
| Re: Battery tray - adjustable easy access concept Yeah, I fortunately do have some free time right now to "play" with ideas. If nothing else, doing this stuff keeps my 3D skills sharp. |
05-01-2012, 04:37 PM | #5 |
| Re: Battery tray - adjustable easy access concept |
05-21-2012, 11:49 AM | #6 |
Ok, I finished making and testing the first unit and I have to say it works very well and weighs almost nothing. I did lower the battery about .25" to lower the C of G slightly without compromising the battery protection. Compared to the original mount, it is 100% easier to take the battery in and out. Effortless. One velcro strap and the battery slips straight up and out. Slip the other one in and secure the velcro. The battery is guided/secured on all sides so there is no need to align it or worry about it moving while driving. Also, the handling appears to be the same. I can't see/notice any difference while driving. The thing I like the most besides easy in-out of the battery, is the fact that the battery is completely protected from rock bites. |
05-21-2012, 12:46 PM | #7 |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
gotta say there are 2 major flaws 1. people with money to spend on aftermarket parts dont have a stock chassis 2. already mentioned cg is way too high, most people run their battery on the lower skid or on the front axle... there are just much better options for the money. |
05-25-2012, 12:35 AM | #8 |
Rock Stacker Join Date: Jan 2012 Location: On the ledge. Look up.
Maybe I'm alone, but I have money to spend on aftermarket parts and I run a stock chassis. Zodiaci, there are about a gazillion RC junkies out there. If you can design your component, build it, then sell it, you will have done more than most people will do. Plus, you'll have learned a lot in the process. And the next idea you have...you'll be able to build on what you've learned. It's how businesses get started. Regardless of how well your component might sell or not sell at all, it's training for that next idea that is the real pay for following through with ideas. Like SkorpionKing, I wish I had your skills for putting an idea onto a screen like that. Mine are always rough pencil sketches, which can make it tough to convey to a manufacturer exactly what you're trying to get them to build for you. That wouldn't be an obstacle for you. Stick with it, even if it doesn't sell. Try it. Maybe what you designed it for is not what someone else thinks to use it for. You designed and built a battery holder, but someone else might discover that it actually works better as...who knows. It happens all the time, even right here on this site. Or it's just another prototype on the shelf. But it's another step in learning how to move something from idea to prototype to product in a more timely fashion every time you take a shot at it. |
05-25-2012, 03:08 AM | #9 | ||
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: Battery tray - adjustable easy access concept Quote:
People choose what they spend their money on If it's something you feel will make it better go for it you'll be none the worse for trying. | ||
05-25-2012, 11:01 AM | #10 | |
I choose to run the stock chassis because it works very well and I like to have a body with a nice paint job. Call me old school or whatever but it's what works for me. The whole reason I designed and made this battery tray was to solve the issues I was having with the stock mount while retaining the stock chassis and body. As you all know, there is practically zero space for a battery between the front links. I tried everything and it just didn't fit well. Links would always hit the battery affecting articulation and the battery was a total pain to remove and install. I considered mounting the battery on the front axle but I didn't want to cut the body for clearance. Paint job is too nice! So, this is what I came up with: -Super easy battery in-out -Very lightweight -Adjustable angle -Strong -Plenty of clearance for the links -Completely protects battery -No noticeable change in handling It works. Oh, and I'm not trying to sell them, I just wanted to show people an "outside of the box" idea to mount a battery on an XR10. Pics are on the way... | |
05-25-2012, 01:10 PM | #11 |
RCC Addict Join Date: Aug 2009 Location: Earth?
Looks good. I like it. |
05-26-2012, 09:37 PM | #12 |
You're not going to offer them for sale? Why not try it? If you've got time to make only four a week, tell people that up front so they expect a wait. But heck, you've got the chance to put something out there. Maybe it raises a little cash to do a next idea. Just my opinion, but I think you ought to at least make it available. It's just a hunch, but something tells me the guys at VP had plenty of work to do with their existing equipment before they decided to float a mod part or two out there and perhaps never expected to be received in the RC crawler world or actually to take/share the lead for quality of parts. |
05-27-2012, 09:11 AM | #13 |
A few pics of the first "rough" prototype: |
05-28-2012, 03:46 AM | #14 |
Pebble Pounder Join Date: Jan 2009 Location: Olympia
Nice work brah! On my xr10 battery mount I'm running a Plastic servo box case i cut and drilled for low cog, it's zip tied to the lower links and and it holds my 3s 1300 perfectly and the battery will fit between the upper links no problem. The 2 Ckrc 3s 1300 lipos I have are kinda big for the front axle so I made this. You can have this design if you want. Didn't cost me a dime! |
06-07-2012, 02:30 PM | #15 |
That's exactly what I did with my XR when I was building it, except that I cold-bent some polycarbonate to do it. Expect a call from my legal counsel to discuss your patent infringement. No, I'm kidding. You did a great job with them. Thanks for posting the photos. |
06-07-2012, 08:30 PM | #16 | |
No, seriously, great minds think alike. | |
06-08-2012, 09:48 PM | #17 | |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
Ya cant use Brandon & Brad...AXIAL TEAM DRIVERS as an example of who runs a stock chassis. It's THEIR chassis & likely...part of their contract to run it. Just like Mark Reels contract. They run the stock chassis because...well they kinda have to & it works for em. Keep designing stuff bro. Not EVERY products gonna be a homerun outta the gate. J.D. | |
06-09-2012, 12:53 AM | #18 | |
RCC Addict Join Date: Jul 2009 Location: AT THE DRAGON'S LAIR
You got drawing skills, if you keep designing, making and testing, you can make a part/s every one cannot live without. There has to be R&D, and trial and error. Good luck man, and good for you for being hands on about it and looking to improve something! | |
06-10-2012, 12:20 AM | #19 |
Pshawww...I've never actually used that phrase. Who cares about a contract? They're using a stock chassis and spanking a whole lot of people with far more expensive setups. |
06-10-2012, 12:23 AM | #20 |
Battery tray - adjustable easy access concept - Similar Threads | ||||
Easy access to transmission? | buffet | Axial Wraith | 10 | 04-17-2012 09:13 AM |
Battery tray & battery options? | Mysterious | Axial XR10 | 10 | 02-18-2012 01:13 PM |
Easy under hood access | OKJeepin | Axial Wraith | 22 | 12-07-2011 06:34 PM |
Front battery access | Supercomputer5 | Axial Wraith | 6 | 08-17-2011 07:19 PM |
BWD Modular Servo Mount/Battery Tray/Adjustable Upper Link Mount | billet works | HPI Wheely King | 18 | 07-05-2010 10:52 AM |
