04-29-2012, 09:12 AM | #1 |
Newbie Join Date: Mar 2012 Location: yorba linda
| tire rub on springs
who runs internal spring shocks.
04-29-2012, 11:38 AM | #2 |
Pebble Pounder Join Date: Jul 2010 Location: malta
| Re: tire rub on springs |
04-29-2012, 11:56 AM | #3 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
im running shocks with the mini t springs with 1' wide vp wheels with 350 hubs and mine just barley touch the shock body at full lock.
04-29-2012, 05:54 PM | #4 |
How far back is your castor? I currently have mine set 1 step further back than max with unmodded c's and I can't steer sharp enough to even touch the shocks. At max stock castor they would just slightly rub to where it isn't enough to worry about Sent from my iPad using Tapatalk |
04-30-2012, 06:45 PM | #5 |
I'm running full stock set up with no caster adjustments. to get any kind of turning radius the tires rub on the shock springs.
05-03-2012, 03:31 AM | #6 |
Quarry Creeper Join Date: Mar 2011 Location: W P, Crawlorado
I run my big bores upside down in the front. Let em rub...the springs are out of harms way.
05-03-2012, 07:07 AM | #7 |
I sort of like the way the springs spin when the tires rub them.
05-03-2012, 08:35 AM | #8 |
Rock Crawler Join Date: Oct 2011 Location: smithville
05-03-2012, 11:02 AM | #9 |
Quarry Creeper Join Date: May 2009 Location: pacific NW
05-03-2012, 01:11 PM | #10 |
| Re: tire rub on springs The Losi golds are too loose at the collar to turn them if you have a good o-ring in there. They will spin off the Jeeping spring retainers but who cares they won't go anywhere.
tire rub on springs - Similar Threads | ||||
4.18 tires and larger, what are you doing about tire rub? | kurtus | RC4WD Trail Finder 2 | 10 | 07-22-2012 04:39 PM |
XR10 Tire and spring rub? | morpheus_tn | Axial XR10 | 21 | 01-31-2012 08:32 PM |
tire rub | ax10newguy | General Crawlers | 10 | 05-08-2010 12:32 AM |
tire rub...wheel offsets? | 73fordhighboy | Duratrax Cliff Climber | 10 | 10-20-2009 01:27 AM |
Axial tire rub | alpinehyperite | Newbie General | 6 | 06-10-2008 08:02 PM |
